Old 06-13-2019, 01:16 PM
stefanboman stefanboman is offline
Default Pan knob above attention fader-Why isn’t it activated?
Why isn’t the pan knob activated above the attention fader?
That knob had never been in function, right?
Seems odd to me that you’ve never been able to pan the attentioned channel(without having to go to the home screen on the MTM).
Also a bit of a waste leaving a centered knob unused.
Stefan Boman
Atlantis Studios-Stockholm
www.parkstudios.se
stefan[at]atlantisstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 06-15-2019, 09:40 AM
creativecontrol's Avatar
Default Re: Pan knob above attention fader-Why isn’t it activated?
It’s a good observation indeed. This encoder has been allocated to behave as an Assignable Knob function, which allows the user to lock any single parameter - such as filter cutoff frequency or Pan by hovering over the param in the DAW and pressing the encoder. The drag is that this has only ever worked for Cubase, Nuendo or Logic, not Pro Tools.
I’m pretty sure Eddie already has a logged definition to allow this encoder to be at least Pan if not any other of the series of available surface functions.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-12-2019, 01:53 PM
Mike Rafone Mike Rafone is offline
Default
Is the Pan Pot on the Attention Module going to be active for Pro Tools in future releases?
Old 07-14-2019, 08:31 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Yes. Its not a Pan pot it will be any knob.
Old 07-15-2019, 06:32 AM
kosmokrator kosmokrator is offline
Is there any plans for that encoder to behave as Jeff said it originally was planned?
Old 07-15-2019, 08:43 AM
EddieJones's Avatar
Not for PT at this time....it will behave like another attention area so you can set the default knobs or quickly change to whatever function you want.
Old 07-18-2019, 02:56 PM
Any ETA on the knob working with Pro Tools?
Dock Fader - Attention Problem spoons Avid S1, S3, Dock and Control App 6 05-15-2018 07:04 AM
Clear the Attention Fader? hixonjames Avid S4/S6 1 07-23-2017 09:10 AM
Attention Fader (??) KeyplayerG Artist Series 3 03-26-2017 06:05 PM
Artist Series Attention select fader bug Cryos Artist Series 1 02-17-2015 04:36 PM
BUYING fader knob for procontrol! MO:SOUND Buy & Sell 0 04-30-2014 03:54 AM
