PT session from a T5 SSD
Has anyone had issues with running/writing/producing a PT session from a Samsung T5 SSD?
Thanks G |
Re: PT session from a T5 SSD
Never used one, but I was immediately suspicious when I looked up the drive and read about "built-in encryption". This is a red-flag in my book, even though they claim it doesn't affect performance.
This reddit thread makes for an interesting read: https://www.reddit.com/r/VeraCrypt/c...encryption_on/ Did you enable/disable encryption, or reformat the drive when purchased new for your system ? mac or pc ? I always reformat a new drive myself (Mac OS Extended Journaled). I then disable Spotlight indexing on any audio drive. (I use 3rd party apps for searching drives). After opening a session, do you wait for your entire session to buffer into RAM before hitting play ? |
The T5 is pretty straight-forward and there's no need to run encryption on it.
The T7 has some fingerprint security mechanism which is probably best avoided. The T5 is a USB disk and pretty fast, provided you connect it to a fast USB port which isn't suffering from any contention. I'll let you use the excellent Wikipedia page to determine if you are actuallly using a fast USB port - things are not always obvious. https://en.wikipedia.org/wiki/USB Internal SSD is generally more reliable - no cables to go bad, no connectors to wear out etc, but plenty of people run video editing sessions from external drives without trouble. I personally prefer to copy everything to internal SSD and then copy the sessions out to external disk for backup and transfer, but I don't work with video and I'm never in a hurry. There were some issues with T5 disks and CCC at one point, but these have been overcome with updates to CCC. |
I've used them exclusively for the last few years. Never had a single problem. Mixing only though. Big sessions, not a glitch. I always run them off a dedicated USB port. They're super portable for taking sessions between studio and home. No power supplies. Would highly recommend. Haven't tried the T7 model yet. Last edited by RichR; 02-19-2021 at 07:52 AM. |
Running T5 and T7 drives as main sample library and recording session drives. Never an issue.
If it is USB3 drive your throughput is determined by that buss. Does not matter if the SSD would transfer terabyte a second, it is limited by USB3. That is enough for plenty, but there are other options for more performance once you need it.
Using it for over a year now.
Flawless so far
...me failing english? That's Unpossible _____________________________________ |
Thank you for the feedback
I have a mix of T3, T5 and T7 now. It's all I've worked off of for several years. Zero issues with any of them.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
Agreed. It's great to have SSD portability when it's needed, but when it's not, I'd much rather work with PCie nvme's for their superior performance.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Recover corrupt session (session backups or importing session data not working) | ejsalling | Pro Tools 2018 | 5 | 04-28-2021 03:54 PM |
Save session, close session, open session next day...clips have moved. | ptr22 | Pro Tools 12 | 8 | 02-18-2016 06:34 AM |
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session | chrisdee | Virtual Instruments | 21 | 10-07-2011 10:02 AM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
