Go Back   Avid Pro Audio Community > Other Products > The Drum Room
  #21
Old 02-06-2010, 07:07 AM
AirborneFO AirborneFO is offline
Default Re: EZdrummer-routing tracks in pro tools
Don't know. I just clicked "tracks" and it seperated everything out. It was a bit of a pain trying to figure out what each aux channel captured. I just played a little beat with everything in there and solo'd each channel. Then renamed the channel based on what I heard. Cymbals didn't have their own "channel". It comes over in the Overhead and Room mix, which is okay. I can totally work with what I have right now.
iMac i5, Pro Tools 10.2, DIGI003 Command, Akai MPK49, Simmons SDK9
AKA: HoFo
"Yes, recording to the system drive is 99% likely THE main problem." sw rec
  #22
Old 02-06-2010, 09:22 AM
cqd cqd is offline
hit the mixer button at the bottom left of ezd..on th mixer page, at the bottom of each channel is its output..set the kick to trk 1, snare to 2 etc...then in pro tools use the different ezd outs as input to your aux/audio channels..should sort it..
  #23
Old 02-09-2015, 09:54 AM
dmarkg dmarkg is offline
I'm using e-drums as a trigger. I want track 1 to be the bass drum, track 2 is snare, track 3 is hi-hat, track 4 is first tom, etc... is this possible?
  #24
Old 02-10-2015, 02:12 PM
Absolutely. As said, you need to start in the EZdrummer plugin and open the MIXER window. At the bottom of each fader, there is a small box where you select the output path. Then add AUX or AUDIO tracks and assign inputs accordingly. Once done, I would save a plugin prest in Ezdrummer(mine was called "DavesMulti"). At this time, you will need to assign the destination tracks each time you create a session, even if you save your setup as a template. This is a known bug that may(or may not) be fixed in PT12(we can dream....) In any case, this can and does work as I have done the same with a Roland TD-10 kit, using EZdrummer, Superior Drummer and Addictive Drums
ezdrummer how to route to seperate tracks? Jim harris Virtual Instruments 6 04-19-2013 10:31 AM
Do you compress and EQ Ezdrummer tracks? tobbenos The Drum Room 5 08-12-2011 08:00 PM
aux tracks and EZDrummer orvillej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-06-2010 04:36 PM
Problem with EZDrummer Midi tracks Artfuldodger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-31-2009 01:08 PM
Routing tracks to headphones WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-05-2004 05:42 PM
