Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 10-07-2009, 12:03 AM
Luke K Luke K is offline
Default EZdrummer-routing tracks in pro tools
hi,
I have been fiddling around with EZdrummer trying to get the drum tracks into separate tracks in pro tools but with no success..
So far all i can get out as a separate track is the kick
can anyone help?
Luke K
Intel Quad Core 2.83 ghz
4 Gig Ram
2x 1Tb 7200rpm seagate Hard Drives
Pro tools 8.0.1
003 Rack
Mackie Mr5 monitors
Windows Vista Home Premium Sp1
Old 10-07-2009, 12:25 AM
abt abt is offline
Default Re: EZdrummer-routing tracks in pro tools
The same way as any VI.
- Set the output of the VI to a bus eg Bus 3-4
- Create a new audio track
- Assign the input of the new audio track to the afore mentioned bus eg bus 3-4
- Record enable the new track
- Hit record
The trick with EZdrummer is to open the Ezdrummer mixer and solo each component one at a time repeating the above until you've got the tracks you need.
Old 10-07-2009, 01:30 AM
- Hit record
Ah! I was trying to assign all at one time but it would not work..so i need to do it 1 by one then? Im pretty sure one of the features somehow was to be able to do it in multiples...Might have to jump on toontrackforums..
Thanks,
Luke K
4 Gig Ram
Pro tools 8.0.1
003 Rack
Mackie Mr5 monitors
Old 10-07-2009, 04:45 AM
Stig Eliassen's Avatar
You can do them all at once. Each kit piece can have its own output from EZD.
Old 10-07-2009, 07:55 AM
jmitchell1532 jmitchell1532 is offline
The whole "solo each track" also works with BFD Lite.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 10-07-2009, 12:12 PM
albee1952 albee1952 is online now
Just go into the ezdrummer mixer window and select the "TRACK", then create the stereo aux tracks in your PT session and set the inputs for the ezdrummer TRACKS. Once you get that setup, save the ezdrummer config as a preset. I have several, including kits with and without cymbals(if the drummer uses real brass). The "no cymbals" presets load really fast.
Old 10-07-2009, 02:13 PM
abt abt is offline
Yeah, you're supposed to be able to do them all at once but I couldn't get it to work. Just do them one at a time, it's easy and doesn't take that long.
Old 10-18-2009, 07:59 AM
Whiteyguitar Whiteyguitar is offline
You can set up the individual outs in one shot, open the EZ Drummer Mixer and on the bottom of every Piece it should say track 1, click on the 1st one and choose Multi and all should go to it's own track. Then Go into PT and Add 8 new Tracks and on the inputs you pick the EZD Plugin, The only thing is EZD only assigns from 2 to 8 so the Kick drum will stay as a VI so you either have to route that thru a Buss or wait till you've tracked the other parts and go back an reassign the Kick to track 2 to 8 which ever one you want to use.
Good luck, it's easier than it sounds......
Stay true to the sound,Less is best
Old 11-19-2009, 07:27 PM
Exclamation Re: EZdrummer-routing tracks in pro tools
I tried that...had all of the tracks from ez drummer routed into imputs (via the plugin bus) but when i record enabled them and tried to record the drum tracks into them i go no sound and no signal?
As far as i can tell im doing it right....any ideas?
4 Gig Ram
Pro tools 8.0.1
003 Rack
Mackie Mr5 monitors
Old 11-19-2009, 08:17 PM
nod25 nod25 is offline
PITA
Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance?
ezdrummer how to route to seperate tracks? Jim harris Virtual Instruments 6 04-19-2013 10:31 AM
Do you compress and EQ Ezdrummer tracks? tobbenos The Drum Room 5 08-12-2011 08:00 PM
aux tracks and EZDrummer orvillej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-06-2010 04:36 PM
Problem with EZDrummer Midi tracks Artfuldodger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-31-2009 01:08 PM
Routing tracks to headphones WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-05-2004 05:42 PM
