Old 08-31-2020, 12:37 PM
Aster Aster is offline
Default Recording midi tracks from Fantom G sequencer
Hi , I am having problems recording / replicating the individual midi tracks from my Fantom G into PT 11. All the midi tracks record on to one channel despite my routing /selecting the right midi channel. Ideally would like to route them individually (1 midi track per FANTOM G midi track) and record at once ? Any Fantom users out there that maybe able to help or users that record externally sequenced midi tracks to PT . I don not really want to export midi tracks from FG and then import to PT.
Old 08-31-2020, 01:25 PM
Top Jimmy's Avatar
Default Re: Recording midi tracks from Fantom G sequencer
Somehow the routing isn’t correct. If each sequencer track is routed to a unique midi channel, and each track in Pro Tools is set to only input a unique midi channel, then you will be able to transfer up to 16 individual midi tracks at once. Somewhere a setting is set to Omni or All when it shouldn’t be.
James Cadwallader
Old 09-01-2020, 02:53 AM
The Fantom G has 16 midi channels. I create a midi track select input Fantom G channel 1 in PT , in Fantom G channel 1 is the piano midi part. When i record it continues to record all midi parts on the same channel. Is there a global setting (PT or in the Fantom G) i need to enable or change something with my routing ?
Old 09-12-2020, 01:32 PM
albee1952 albee1952 is online now
I'd start by reading the Fantom manual to see if there is a way to export the midi files onto a USB stick(or over USB to your computer).
Old 09-12-2020, 05:20 PM
Southsidemusic's Avatar
Look for a setting on the Roland called ”Local On/OFF” and set that to Local OFF and you should be good
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Pro Tools and Roland Fantom midi recording theman1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-17-2007 01:30 PM
Recording Midi from External sequencer 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-13-2006 01:19 PM
Problems Recording MIDI from an External Sequencer RMW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-05-2005 11:17 AM
PT midi tracks or reason sequencer? deejfro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-25-2005 11:23 AM
Transfering note data from a sequencer to the sequencer of the digi 001 sequencer? MichaelK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-05-2000 12:29 AM
