  #51
Old 12-28-2020, 11:46 AM
TOM@METRO's Avatar
Default Re: CPU error 9173
Whoever does not do clean install of OS should not be allowed to buy PT
A clean OS install would solve the vast majority of uncommon issues.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #52
Old 12-29-2020, 09:50 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by GJmoulder View Post
HI Guys, thanks again for all of your input. Im learning from it. I would like to stay with Windows if possible as i have never used a Mac before. I have just been looking at a system within my budget and would value your opinion on wether or not this would do the trick
Processor : 10th Generation Intel® Core™ i5-10400 Processor (6 Cores / 12 Threads, 2.90 GHz, up to 4.30 GHz with Turbo Boost, 12 MB Cache)
Operating System : Windows 10 Home 64
Memory : 16 GB UDIMM DDR4 3200MHz
Storage : 512 GB M.2 2280 SSD
I'd go for the 15 10600k instead, at 4.1GHz, turbo 4.8GHz. You can easily overclock it to 5GHz if you are so inclined. PT isn't the most CPU efficient DAW out there; you'd be better off with the fastest processor you can get. 2.90GHz won't cut it. While you're at it, upgrading your RAM to 32GB wouldn't be a bad idea at all.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #53
Old 12-29-2020, 09:58 AM
lesbrunn's Avatar
With the exception of Apple laptops, I prefer Windows desktops because they are much easier to either custom build or upgrade.
  #54
Old 12-29-2020, 11:21 AM
I can relate. Though I would not easily use Windows, the hardware Apple sells is ridiculously expensive
  #55
Old 12-29-2020, 11:49 AM
lesbrunn's Avatar
With the exception of the new M1 machines...
  #56
Old 01-04-2021, 04:06 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Have you checked your CPU temps???
I know you have a PC, but I7 processor is I7.
I noticed my Mac Mini Late 2012 2.6 I7 quad core started giving me 9173.
Found my CPU temps were 80C at idle and hitting 100C during prints.
at 100C the CPU goes into self preservation mode, and throttles back.
Meaning slower CPU and 9173 errors.
Solved by some new thermal paste on the CPU/GPU heatsink.
20C cooler!!!!
IMDB
  #57
Old 01-04-2021, 07:04 PM
20C cooler!!!!
This is my one complaint about any generation of Mini's - they tend to run on the hot side. Apple screwed up on the heat/airflow on those machines.
  #58
Old 01-05-2021, 06:33 AM
It is designed to be a nice looking heat sink
  #59
Old 01-05-2021, 06:51 AM
A smaller version of the G5 cheesegrater eh
  #60
Old 02-11-2021, 10:40 PM
boxturtle boxturtle is offline
Agreed. You can fry an egg on them!
New to -9173 error uteroid Pro Tools 2019 8 11-29-2019 12:25 PM
AAE error -9173 nikydvt Pro Tools 12 11 01-14-2017 04:05 PM
AAE error -9173 on PT 12.4 marcnyc Pro Tools 12 2 06-24-2016 03:27 PM
-9173 error in PT 12 ArKay99 Pro Tools 12 10 06-11-2016 01:41 AM
