Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 04-15-2020, 11:45 PM
paulisdead paulisdead is offline
Default Transferring ADAT tapes with MBox Pro (getting low levels from outputs)
During the lockdown, I'm taking this opportunity to finally transfer some of my old ADAT tapes to Pro Tools 12.
However, I'm having some issues with the input levels going to the MBox. The levels I'm getting are LOW, I mean around -70 db low.
Set up:
  • Alesis 20 bit ADAT
  • Unbalanced Phono outputs via RCA cable to Unbalanced 1/4" adaptors
  • Inputs 1-6 on the MBox Pro
I've switched between the +7/-10 and have noticed no difference (the ADAT recorder is -10 dBv output according to the manual).
I have tried a different analogue audio source using the same cables and have found no issues (i.e. I get normal levels).
I know this is a cumbersome and low-rent low of doing this, but I've got the time to do multiple passes.
Is the issue with the ADAT's output or my cable set-up? Should I invest in a snake or bite the bullet and invest in a ADAT to firewire solution (003 rack)?
Old 04-16-2020, 12:02 AM
Top Jimmy's Avatar
Default Re: Transferring ADAT tapes with MBox Pro (getting low levels from outputs)
It does sound like there’s an issue with the analog outs on the ADAT machine. If you know anyone else doing production, I’d beg, borrow or rent an interface with ADAT optical on it to make sample accurate transfers.
James Cadwallader
Old 04-16-2020, 12:23 AM
Mark Ziebarth Mark Ziebarth is offline
Try to rent or borrow a audio interface with adat optical inputs. For example an RME Digiface...
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 04-16-2020, 12:44 PM
Best
Mark
Or Digi002 or 003
Old 04-16-2020, 12:48 PM
Originally Posted by albee1952 View Post
Or Digi002 or 003
yes, exactly right. But only if you’re an Avid hardware aficionado...
Old 04-16-2020, 01:02 PM
AE AE is offline
you also have ELCO connectors for balanced outputs, right? these should be +4, so maybe look around for an ELCO to 1/4" TRS or XLR cable?
Old 04-18-2020, 03:06 PM
I just figured that its a solution that doesn't cost much(since this may never get used again), and with ADAT connection, the quality of the interface/converters won't matter at all Re Elco connections, I think there were a lot of ADAT machines that didn't have those and were only RCA for analog connection(which I would only use as a last resort)
Transferring ADAT tapes with MBox Pro paulisdead FireWire & USB Audio Interfaces (Win) 3 08-01-2017 04:15 PM
Transferring DA38 tapes HSLand Pro Tools TDM Systems (Mac) 7 05-04-2017 08:28 AM
Help with transferring ADAT tapes to PT - clock issues? gleiter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-25-2008 03:17 PM
2 tapes, 1 Adat keny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-19-2002 12:22 AM
Good source for ADAT tapes Gingley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-01-2002 02:15 PM
