Old 10-25-2010, 05:21 PM
Benoni's Avatar
Benoni Benoni is offline
Default Behringer FCB1010 Uno Eprom Sysex File For The Eleven Rack
Here is the link to the Sysex file for the FCB1010 with UNO Eprom to work with the Eleven Rack. I have included the instructions from the http://www.voes.be/fcb1010/howto.htm website in PDF files.
Eleven Rack Uno eProm Sysex File - Download -
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 10-25-2010, 09:18 PM
cessnapilot cessnapilot is offline
Default Re: Behringer FCB1010 Uno Eprom Sysex File For The Eleven Rack
Like
Old 12-30-2010, 05:25 AM
Benoni's Avatar
Links have been updated. Removed Dead link. 3 functioning links. Enjoy.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-04-2011, 06:17 PM
Random Dude Random Dude is offline
Hope you don't mind, but this is a good topic and I thought that I'd mention that I uploaded a sysex of mine over on the UNO user group. I can't post an attachment here, but it's in the files>applications section.
What this one does is break up each bank into 4 presets (just like 11R does). Of course you can move them around how you want, but it's probably easier to orgainze each bank on the 11R for a song or something anyway.
So I would organize a bank like this:
A1- clean
A2- rhythm
A3- crunch rhythm
A4- amazing lead tone
Do that for each bank A-Z
Then on the right hand side of each patch select which stompbox is enabled by default in that patch. Most of the time it's reverb. I only set up bank 0-6 in this sysex, but you should see where I was going with it. This way the lights on the buttons reflect the state of the effect when you select the patch.
The only crazy things here that may need to be changed for you is that I use the first row for stomps. You can swap that in the settings tab of Ripwerx (which I hope you are using to begin with ). The other thing is that I use button 10 to turn the wah on and off. If AVID would create an auto-engage setting it would actually not suck to use the wah pedal on this. Heck even if they let use the external button to turn it on and off we could at least try to jam a little momentary switch under the pedal.
Regardless I thought that I'd share this here and hopefully it gives some ideas to other people.
If you are looking at the file and wondering what's going on with PC's at it's because the bank select has to be done prior to the program changes. 11R's bank select is CC32 and the value for user bank is 0 and for factory is 1.
Behringer FCB1010 with Eleven Rack Kruegmeister Eleven Rack 11 12-13-2015 08:31 PM
fcb1010 w/eleven rack Rob487 Eleven Rack 27 09-09-2012 03:53 PM
FS: Eleven Rack with FCB1010 Foot Controller J-mo Buy & Sell 0 07-08-2012 11:27 AM
Eleven Rack Midi / FCB1010 issues..... xbearxau Eleven Rack 28 12-19-2010 08:13 PM
How do I use Eleven Rack with FCB1010!?! zenabi916 Eleven Rack 6 11-22-2010 01:31 PM
