Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 07-20-2020, 09:50 AM
mtung mtung is offline
Default delay compensation difference between native and HDX
I've been meaning to ask this for a while...
Same mix:
On a native system Delay Compensation lights green and all is OK.
On HDX system, Delay Compensation is red and can't compensate.
I think it's been like this for a while, I just wondered what is usually the cause. Can a bad plugin do this or is this a limit of the HDX system?
thanks
Old 07-20-2020, 11:10 AM
XJENSEN XJENSEN is offline
Default Re: delay compensation difference between native and HDX
Well, 'same mix' only of you use all native plugins in your HDX session as well.
Probably you're creating some DSP-Native round trips that add the extra latency.
Old 07-20-2020, 11:58 AM
Farhoof's Avatar
Farhoof Farhoof is offline
The mixer is always DSP. So if you put a native insert in an aux, you are going dsp (input bus) -> native -> out another bus so dsp again.
I believe the added delay is exactly the hardware buffer length for each step, so you can try and lower that.
If you have 3 inserts; native > dsp > native, set the middle one as native as well. (assuming the others are not available as dsp)
Old 07-20-2020, 12:32 PM
Only native plugins in the mix, so this must be a byproduct of having to use the the dsp mixer on the HDX card. It’s just very frustrating. I can try to lower the buffer size, and sometimes that works but it most often does not.
Audio quality and Delay Compensation difference between Ultimate and Standard?? Simon2065 Pro Tools 2019 3 06-12-2019 04:20 AM
Still no Side Chain Delay Compensation for Native?!?! thebeatless Pro Tools 2019 7 05-11-2019 12:26 AM
HD Native vs HDX hardware insert delay compensation? MixerGuy Pro Tools HDX & HD Native Systems (Mac) 2 08-14-2018 06:56 PM
no side chain delay compensation for HD Native users OliverH Pro Tools 11 50 09-02-2017 02:36 PM
HD Native Delay Compensation not working! nuancerec Pro Tools HDX & HD Native Systems (Mac) 10 01-24-2011 04:12 AM
