Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 07-17-2020, 09:34 AM
stopi stopi is offline
Default MIDI IN doesn't work in PT, only in THRU mode
Hello! In my Pro Tools 2019.12 ther's no MIDI workin on Instrument track. If I enable THRU mode there is working but with long latency. What's goping on? I have RME Fireface UC as MIDI interface. When I run virtual instruments as standalone all works fine so there is not problem in connection or cables. Under PT not working...
I try just to control standard virtual instruments as Kontakt and similar on instrument track. I put plugin on track, select input as "Predefined UC Port 1" and MIDI output to Plugin. My keyboard is Motif 8 and all is set to channel 1 and connected tu Port 1 of Fireface interface.
Glissando - an easy technique for playing fast arpeggios and licks.
Old 07-17-2020, 09:51 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: MIDI IN doesn't work in PT, only in THRU mode
Please take a look at the Help Us Help You page that is linked in the forum header.
Janne
Old 07-18-2020, 12:16 PM
First off according to the compatibility chart PT 2019.12 isn't considered compatible with Windows 7. But that's not the real issue here. You need to read the manual. Open PT's Preferences and on the MIDI tab make sure that the 'Default Thru Instrument' field is set to 'first selected MIDI track'. There's no MIDI assignment you have to make - it's all done by the instrument track.
Jack
QAPLA!
Old 07-18-2020, 03:40 PM
And, what setting is the Playback Buffer set to? 64 is preferred and anything above 128 will likely have too much latency(delay)
PT10.3.9 HUI Mode with Yamaha 02R96 doesn't work mrpollack Windows 1 11-20-2014 03:41 AM
Slip Midi Edit Mode Doesn't Work Jampa9 Windows 0 11-15-2014 06:02 PM
Protools 11 doesn´t work with HUI control mode? germanysantosarreola Pro Tools 11 11 07-04-2013 10:45 PM
spot mode sometimes doesn't work Bryan Cook Post - Surround - Video 7 12-20-2003 09:04 AM
"Monitor Mode" doesn't work anymore. Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-24-2001 05:05 AM
