Old 04-12-2012, 04:54 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Low Latency Monitoring and Hardware Inserts
I'm having some strange behaviour with hardware inserts and LLM.
If I have a track sending to the LLM nominated outs (1-2 in this case), and I use a hardware insert, the track no longer passes through my 1-2 master track plugins (L2007 in this case), if I make the harware insert inactive, the track is now effected by the master track plugins. (The mentioned track is not in record either).
I checked the manual, but couldn't find this specific situation noted.
Can anyone else recreate this?
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT 2020.......
Old 04-12-2012, 07:43 PM
cananball cananball is offline
Default Re: Low Latency Monitoring and Hardware Inserts
LLM disables plugins. This is normal behavior AFAIK
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
Old 04-12-2012, 08:51 PM
Only if you're in record. This is disabling the master section when not in record.
Old 04-13-2012, 05:03 PM
No-one? Avid?
I'm actally finding LLM so hard to work with, its almost useless.
I turned it on in an old session the other day, and it muted the bass. It wasn't a well played bass, but it should be my call to mute it, not the programs.
Restart tha Mac, and it came good again.
Old 04-13-2012, 07:20 PM
danander11 danander11 is offline
The bass playing or the audio?
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 04-13-2012, 08:32 PM
necjamc necjamc is offline
That gave me a good laugh.
Old 04-14-2012, 12:48 AM
Nice
I wonder how an artist would feel if you said.."That take was so bad I need to reboot."
Old 04-15-2012, 04:51 PM
Bump...Still wondering about this one.
Old 06-18-2012, 07:31 AM
mu-tron-kid mu-tron-kid is offline
One of my Colleagues just experienced this same error on a PT 8 LE with 002 rig.
Toggling LLM off seems to have solved it, but yes, with a couple of Hardware inserts, the audio was not passing to the Bounce...
Additionally, RTAS plug-ins placed AFTER the Hardware Insert were not having any audible effect...
No Tracks Record Enabled.
Brian Dozoretz
Mac Pro, osX.10.12.6, PT 2018.3 HDX, 2 x Alpha/Deltalink
2 x iMac, osX.10.12.6, PT 2018.3 HD Native PCIe + HD Omni
iMac, osX.10.12.6, PT 2018.3 HD Native PCIe T-Bolt expansion chassis + HD io, Artist Series Mix x 2, Artist Series MC Transport
VENUE SC48 3.1
SSL Duality via ipMIDI / ∂elta Automation Plug-In
Old 06-21-2012, 08:08 AM
LLM will disable inserts AND sends. If you want to record thru hardware, its best done before conversion. You CAN do it by turning LLM off and running at a low buffer, but you will suffer the latency from the extra chain of conversion(out to the hardware and back in).
Latency Compensation on Hardware Inserts BJosephs macOS 6 07-11-2011 06:45 AM
Third party hardware and Low Latency Monitoring The Dougfather Pro Tools 9 3 11-05-2010 07:03 PM
latency when using hardware inserts (oo3) earmeter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-14-2008 06:38 PM
[002R] Hardware Inserts Latency: how much is it? HotRats_Reloded 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-14-2006 01:03 PM
latency on hardware inserts vtone Tips & Tricks 4 10-22-2000 05:37 AM
