Old 03-11-2011, 08:54 AM
earshatter earshatter is offline
Default LE static/crashes during playback?
Using a Macbook Pro, Leopard 10.6.3, mbox2, dv toolkit2, one ext sfx hard drive, one ext work drive. H/W buffer-1024, cpu usage-80%, DAE playback buffer-lvl 1. Using 36 tracks, but only have 31 active, and the session is far from full. Have QT vid active. Also, playing back in headphones, not through amp.
Problems:
1) when playing back, at random times, there will be static on top of the audio. I can still hear my tracks, but the bleed of the static goes in and out. Tried to adjust the buffers, seemed to work for a while, then just comes back.
2) I have my drives daisy chained as follows (since there is only one friggin 800 port!?), from computer-1TB drive sfx drive-to work drive. I had to change this way because PT crashed every 5 edits with reverse configuration. Using USB800 ports, as I don't have sata connection nor 400 connection. I am also crashing when using the file finder within PT to find sfx. Had to give up my tower, so can't use soundminer anymore.
Any ideas as to how I can streamline the system so at least I am not crashing? I'm not overloading the system...yet. My session will become larger as the movie goes along, however, right now I'm just starting this movie.
This is driving me crazy (excuse the pun!).
Any help is appreciated.
Absence of evidence is not evidence of absence...the truth is out there.
Protools 9.0.6 'static on playback' & no PT Headphone playback vcoad Windows 1 03-14-2013 04:09 PM
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou JLue Pro Tools 9 1 08-04-2011 08:59 AM
Fuzzy Static with ProTools playback and window media files playback 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2011 05:41 PM
Static "Playback" with Protools and Static "Playback" with windows files 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-20-2011 05:57 AM
192 crashes with static charge DavidKLA Pro Tools TDM Systems (Mac) 4 11-27-2010 01:39 PM
