Old 12-13-2005, 09:13 PM
PTGuy PTGuy is offline
Default Sudden problem (-50) error; can\'t save
very strange but this just started happenning today. I can't save (or quit for that matter) a file. When I try to it just says "-50 error" and nothing about DAE. The only TWO things I did was update the firmware on my Midi I/O (which PT would see only 50% of the time) and I moved my ilok key to another open USB spot.
Anyone ever have this?
BTW> when I do a search for anything it just throws up random posts. I am checking all the right categories and even using "" on most but I am getting horrible results...
Old 12-14-2005, 01:56 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Sudden problem (-50) error; can\'t save
Have you tried the obligitory trash prefs and DIGI databases!!
Also check privileges(right click on a drive volume) on your hard drive volumes and repair disk permissions from disk utility.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-14-2005, 11:42 AM
mylar mylar is offline
I have just had the same thing happen to me. I can see the file in the audio files folder but when I try to import it, PT says "aif1.01 is unreadable by pro tools"
When I finished my recording I got an (-50) error; can't save message.
I had changed the folder during the recording process. Also when I Apple key I (info) the file It says that it's 335 megs.
Does anybody have a work around in mind?
Old 12-14-2005, 02:34 PM
crizdee's Avatar
You need to look at either "save session data as" to create a new session (and include all audio) or open a new session and use "import session data"
Moral of this session is, don't changed folder/names/detaisl during a session!!!
Also trash Digi databases on all volumes to refresh them all.
Chris
Producer, Engineer,
www.ukmastering.com
(-50) ERROR on Save / Auto Save oldrake macOS 1 10-14-2013 03:30 PM
Auto Save error (seems like a major Protools 9 Problem) guileman Windows 77 07-10-2013 12:11 PM
HELP! Sudden error - Possible RAM problem Mullis Digidesign Hardware & Software 1 11-14-2006 12:01 PM
Sudden BFD problem darrenriley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-01-2006 04:59 PM
URGENT disk error / save session copy in.. problem viaspiaggia Pro Tools TDM Systems (Mac) 7 09-17-2003 07:21 AM
