Old 09-21-2007, 08:35 AM
paul_g's Avatar
paul_g paul_g is offline
Default Question about setting up a session files, saving/bouncing
Hi All,
I recorded my first band practice last night, and I must admit, I'm so impressed. It came out great.
Here is the scoop: I setup a file called "band template". which has all the tracks and settings and routings of 6 Tracks total. I figured rather than creating a new session each time, just have one template, right?
After each recording, I did a "File / Save As" and gave the new session a new name. However, in doing so, each session has the regions from the previous session. By the end of the night, each song had all the regions of other songs. So, if I'm in Song B and delete the regions of song A, song A can no longer find the regions... Yikes!
Also, if Song B runs shorter than Song A and I Bounce Song B to MP3, the remaining regions from Song A will also record to the MP3 after song b is finished playing.
What is the best practice to record a band practice?
Thanks in advance! pg
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 09-21-2007, 10:22 AM
soundonsound soundonsound is offline
Default Re: Question about setting up a session files, saving/bounci
You can record everything in one session template.
Then use the selector tool to highlight from song A start to song A end. Then Bounce to disk will only bounce the timeline selected. Pretty easy to seperate songs in bouncing.
Then if you want to take it a step further, you can do a File > Save Copy In, in the items to copy box on the save copy in window, check 'All Audio Files'. And Make an entire backup of the whole practice. Open up the new copy and make sure its all there.
Now you can basically open one of them highlight and delete all audio except one song, Clear the Region bin of unused audio files and then do another save copy in with all audio files.
Basically you can piece out new sessions of individual songs if you do it like this.
Maybe someone can simplify this explanation if it doesn't make sense...
Old 09-21-2007, 04:31 PM
Cam9021 Cam9021 is offline
Default Re: Question about setting up a session files, saving/bouncing
If I understand correctly what you want, you want to set up a session template then just open it up and it's all set to record? If so, set it up the way you want, inputs, plug-in's, etc, and save it without any recordings on it. Save it as your template. Then open it up and do a "Save As" from that, then do your recording from the new Save As. That way no regions are on it because nothing has been recorded. There's also a way to make your file a Read Only so that it can only be used with a "Save As" command. I'd have to look it up to see how to do that, but as long as your file is only used as a template it shouldn't be a problem.
Dan'o
Old 09-26-2007, 12:52 AM
bigr31 bigr31 is offline
COULD NOT COMPLETE THE BOUNCE TO DISK COMMAND BECAUSE ASSERTION IN "/VLOUMES/DEVELOPMENT/VB_CLIFF/ALTURAPORTS/NEWFILELIBS/FILEFORMAT/MACBUILD/../../FF_AUDIOPROPERTY.CPP", LINE 33.
This is the error I get when I try to bounce a file that's only 30 sec long. Mind you I can bounce the whole track which is 3:50 sec long and I can also bounce the file at 28 sec long and can't do a 30 sec bounce. What am I doing wrong, please help
I have a mini mbox and 002 with a macbook pro 10.4.10 2.2ghz 2gb 667 Mhz DDR2 SDRAM.
Old 09-26-2007, 12:55 AM
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 03:42 AM
Saving Session with Associated Files Calum M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-25-2006 03:17 PM
Having problems saving session files in mbox Kerby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-30-2004 02:48 PM
Saving Session Copy files. new engineer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2002 09:29 AM
Saving session files/Trashing audio files digigirly Tips & Tricks 2 02-08-2002 09:55 AM
