Old 03-19-2017, 12:11 PM
Marco73 Marco73 is offline
Default Mini grand problem - reverb and digital/distorted sound on notes
Hi there, new to all of this. Just loaded up pro tools and set up a track with mini grand. When I hit the keys I can hear notes through my speakers but they've all got a reverb and digital/distorted sound attached to them. There are no other inserts attached to the track.
Why could this be?
Mark
Old 03-19-2017, 02:26 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Mini grand problem - help!
Why could this be?
Mark
Not really enough information about your routing to help. but i would suggest starting a new session with just one instrument track and insert Mini Grand and see what happens. also try different presets within mini grand. check the effects balance isn't right up as the mini grand has built in reverb so maybe its getting turned to 100% wet somehow, so check this is down to around 10-20% to test.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-19-2017, 06:45 PM
leftalive leftalive is offline
If you're on a mac running Sierra there's a known issue with Mini Grand and Structure. Just do a search to find more about it. We're waiting on a fix from Avid.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 03-27-2017, 12:21 AM
Default Re: Mini grand problem - reverb and digital/distorted sound on notes
Thanks both - all sorted
Old 05-14-2018, 03:58 PM
anouaux anouaux is offline
How did you resolve the issue with your mini grand?
I am currently experiencing the same issue you described.
AIR Mini Grand: no 'long' sound, just short notes dvdr Virtual Instruments 266 08-20-2018 11:40 PM
Mini Grand Problem PierceJ Pro Tools 10 1 09-19-2015 08:14 AM
Mini Grand in PT9 no sound and crashes. eddicuz Virtual Instruments 0 04-04-2011 12:46 PM
Mini Grand instrument track being distorted after bounce mrtibbs Pro Tools M-Powered (Win) 1 11-18-2009 01:05 AM
Mini Grand problem galliv Pro Tools TDM Systems (Mac) 8 01-12-2009 12:06 PM
