Can't get pro tools 11 to rewire reason 7
Good day my avid family has anybody successfully rewired pro tools 11 with reason 7 ? I've tried everything under the sun and still no after party. I'm using a mac pro, osx 10.7.5 lion 2x3 ghz quad core 16 gb of ram. I made sure that both reason and pro tools are in 64bit mode and began the process. Pro tools well open reason just can't get the reason interface to read in slave mode. Any ideas sure would ease my pain.
Re: Can't get pro tools 11 to rewire reason 7
To use Reason 7 in PT11: open PT, create an Instrument track and insert Reason in an insert slot. The Rewire client will open Reason and the Reason gui should come up. Reason has recently been updated to 7.1 and you also get a free rack effect called Synchronous. |
+1 to working fine.
In 7.1 PT's 11.1.2, I need to manually set the rewired outputs (PT's insert) (Mix L Mix R). This is the only change in behavior I've noticed.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Same here; no biggie
Maybe something's wrong with the rewire plugin. I'd try to reinstall reason just in case.
re: reason's insert outputs, even in 7.0.1 you have to manually assign them to Mix L Mix R. No biggie indeed but I wonder why they're not automatically assigned by default anymore.
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc |
This got Reason 8 to show up in PT11 for me. http://www.pro-tools-expert.com/home...ewire-bug.html
I am using Reason 6.5 with both PT 11 and 10. Is Reason 32 bit enabled? I had the reverse problem with PT10 (32 bit wasn't enabled). Just a thought.
Pro Tools 11 and Reason 7.0.1 with Rewire | DonaldM | Pro Tools 11 | 0 | 08-15-2013 01:20 PM |
pro tools 10 to reason 5 rewire ? | zzzz | Pro Tools 10 | 0 | 07-12-2013 05:27 AM |
Pro Tools SE Rewire to Reason??? | donny4sho | Pro Tools SE and Essential (Win) | 0 | 05-17-2011 03:03 PM |
Using reason through Pro tools, Rewire *HELP* | Mitai | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-13-2006 09:12 AM |
Cant Rewire Reason to Pro Tools | choodelphia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-28-2005 12:00 PM |
