digital distortion on audio recording only
I'm running PT 10.3.6.269 on an iMac 3.4 GHz Intel Core i7 (OSX 10.8.4), max'ed out on ram.
I can import audio, play it back, use software synths, all the bells and whistles, no problem. But as soon as I put something in record (vocal or guitar) I get digital distortion (to tape). I've ditched all the prefs, done disk utility, upgraded both pro tools and Apogee Symphony. I've tried taking ALL my plug-ins out of its folders. No luck. When I run the exact same system on my MacBook (with the symphony) I have no problems. Has anyone come across this problem? I'm used to an overall digital distortion which I fix through switching from 128 to 256 etc. But this ONLY happens on the audio channel I'm trying to record on. Thanks |
Re: digital distortion on audio recording only
I forgot to mention that this happened overnight. My system has been running smoothly on the iMac for over a year.
Is the symphony clocked to anything? ADAT? W/C?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
No, within ProTools (command 2) it says "See Control Panel". On my Symphony it says "Internal" which I take it means within Protools itself.
Are you certain the session sample rate and the hardware device's sample rate are the same?
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
session is 44.1 and my Apogee is too.
What exact model iMac (model number/date code), what are all the disk drives installed in it or external, what are their make/model/rpm specs (if not SSD) and for external drives how are they connected (USB, thunderbolt etc). Which of these drives is the dedicated audio/session drive required by Pro Tools? If external drives are daisy chained with each other or peripherals describe that.
Have you fully optimized this system? Including disabling spotlight indexing (do that on all drives for now, not just the audio/session drive), disabling WiFi and Bluetooth. Etc. etc. Make sure ecery last optimization is done. Make sure no third party antivirus crapware is running (if so fully uninstall it). |
Towards the end you can see two drives, "Machfive" which houses all external soft samplers (Kontakt, Omnisphere etc.) and then "Audio" to which I record audio from Pro Tools.
thanks Kristian Model Name: iMac Model Identifier: iMac12,2 Processor Name: Intel Core i7 Processor Speed: 3.4 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 8 MB Memory: 16 GB Boot ROM Version: IM121.0047.B1F SMC Version (system): 1.72f1 Intel 6 Series Chipset: Vendor: Intel Product: 6 Series Chipset Link Speed: 6 Gigabit Negotiated Link Speed: 3 Gigabit Description: AHCI Version 1.30 Supported WDC WD1001FALS-403AA0: Capacity: 1 TB (1,000,204,886,016 bytes) Model: WDC WD1001FALS-403AA0 Revision: 06.01D02 Serial Number: Native Command Queuing: Yes Queue Depth: 32 Removable Media: No Detachable Drive: No BSD Name: disk0 Rotational Rate: 7200 Medium Type: Rotational Partition Map Type: GPT (GUID Partition Table) S.M.A.R.T. status: Verified Volumes: disk0s1: Capacity: 209.7 MB (209,715,200 bytes) BSD Name: disk0s1 Content: EFI Macintosh HD: Capacity: 999.35 GB (999,345,127,424 bytes) Available: 632.25 GB (632,245,686,272 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk0s2 Mount Point: / Content: Apple_HFS Recovery HD: Capacity: 650 MB (650,002,432 bytes) BSD Name: disk0s3 Content: Apple_Boot Macintosh HD: Available: 632.25 GB (632,245,415,936 bytes) Capacity: 999.35 GB (999,345,127,424 bytes) Mount Point: / File System: Journaled HFS+ Writable: Yes Ignore Ownership: No BSD Name: disk0s2 Volume UUID: Physical Drive: Media Name: WDC WD1001FALS-403AA0 Media Medium Type: Rotational Protocol: SATA Internal: Yes Partition Map Type: GPT (GUID Partition Table) S.M.A.R.T. Status: Verified FireWire Bus: Maximum Speed: Up to 800 Mb/sec OXFORD IDE Device LUN 0: Manufacturer: Glyph Technologies Model: 0x1 GUID: 0x94902E0512E41 Maximum Speed: Up to 400 Mb/sec Connection Speed: Up to 400 Mb/sec Sub-units: OXFORD IDE Device LUN 0 Unit: Unit Software Version: 0x10483 Unit Spec ID: 0x609E Firmware Revision: 0x138 Product Revision Level: 3.AA Sub-units: OXFORD IDE Device LUN 0 SBP-LUN: Capacity: 500.11 GB (500,107,862,016 bytes) Removable Media: Yes BSD Name: disk4 Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Not Supported Volumes: disk4s1: Capacity: 32 KB (32,256 bytes) BSD Name: disk4s1 Content: Apple_partition_map disk4s2: Capacity: 29 KB (28,672 bytes) BSD Name: disk4s2 Content: Apple_Driver43 disk4s3: Capacity: 29 KB (28,672 bytes) BSD Name: disk4s3 Content: Apple_Driver43 disk4s4: Capacity: 29 KB (28,672 bytes) BSD Name: disk4s4 Content: Apple_Driver_ATA disk4s5: Capacity: 29 KB (28,672 bytes) BSD Name: disk4s5 Content: Apple_Driver_ATA disk4s6: Capacity: 262 KB (262,144 bytes) BSD Name: disk4s6 Content: Apple_FWDriver disk4s7: Capacity: 262 KB (262,144 bytes) BSD Name: disk4s7 Content: Apple_Driver_IOKit disk4s8: Capacity: 262 KB (262,144 bytes) BSD Name: disk4s8 Content: Apple_Patches 500: Capacity: 499.97 GB (499,972,702,208 bytes) Available: 215.28 GB (215,275,474,944 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk4s10 Mount Point: /Volumes/500 Content: Apple_HFS ATA Device 00: Manufacturer: Glyph Technologies Model: 0x0 GUID: 0x94902E073149D Maximum Speed: Up to 800 Mb/sec Connection Speed: Up to 800 Mb/sec Sub-units: ATA Device 00 Unit: Unit Software Version: 0x10483 Unit Spec ID: 0x609E Firmware Revision: 0x103 Product Revision Level: LC11 Sub-units: ATA Device 00 SBP-LUN: Capacity: 750.16 GB (750,156,374,016 bytes) Removable Media: Yes BSD Name: disk1 Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Not Supported Volumes: disk1s1: Capacity: 32 KB (32,256 bytes) BSD Name: disk1s1 Content: Apple_partition_map MachFive BU: Capacity: 750.02 GB (750,022,115,328 bytes) Available: 221.46 GB (221,456,142,336 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk1s3 Mount Point: /Volumes/MachFive BU Content: Apple_HFS Oxford ATA Device 00: Manufacturer: Glyph Technologies Model: 0x0 GUID: 0x94902E0740A31 Maximum Speed: Up to 800 Mb/sec Connection Speed: Up to 800 Mb/sec Sub-units: Oxford ATA Device 00 Unit: Unit Software Version: 0x10483 Unit Spec ID: 0x609E Firmware Revision: 0x103 Product Revision Level: CC37 Sub-units: Oxford ATA Device 00 SBP-LUN: Capacity: 1 TB (1,000,204,886,016 bytes) Removable Media: Yes BSD Name: disk2 Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Not Supported Volumes: disk2s1: Capacity: 32 KB (32,256 bytes) BSD Name: disk2s1 Content: Apple_partition_map disk2s2: Capacity: 29 KB (28,672 bytes) BSD Name: disk2s2 Content: Apple_Driver43 disk2s3: Capacity: 29 KB (28,672 bytes) BSD Name: disk2s3 Content: Apple_Driver43 disk2s4: Capacity: 29 KB (28,672 bytes) BSD Name: disk2s4 Content: Apple_Driver_ATA disk2s5: Capacity: 29 KB (28,672 bytes) BSD Name: disk2s5 Content: Apple_Driver_ATA disk2s6: Capacity: 262 KB (262,144 bytes) BSD Name: disk2s6 Content: Apple_FWDriver disk2s7: Capacity: 262 KB (262,144 bytes) BSD Name: disk2s7 Content: Apple_Driver_IOKit disk2s8: Capacity: 262 KB (262,144 bytes) BSD Name: disk2s8 Content: Apple_Patches Audio: Capacity: 1 TB (1,000,069,726,208 bytes) Available: 267.81 GB (267,813,990,400 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk2s10 Mount Point: /Volumes/Audio Content: Apple_HFS Oxford ATA Device 00: Manufacturer: Glyph Technologies Model: 0x0 GUID: 0x94902E07403E7 Maximum Speed: Up to 800 Mb/sec Connection Speed: Up to 800 Mb/sec Sub-units: Oxford ATA Device 00 Unit: Unit Software Version: 0x10483 Unit Spec ID: 0x609E Firmware Revision: 0x103 Product Revision Level: CC13 Sub-units: Oxford ATA Device 00 SBP-LUN: Capacity: 2 TB (2,000,398,934,016 bytes) Removable Media: Yes BSD Name: disk3 Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Not Supported Volumes: disk3s1: Capacity: 32 KB (32,256 bytes) BSD Name: disk3s1 Content: Apple_partition_map MachFive: Capacity: 2 TB (2,000,264,675,328 bytes) Available: 426.97 GB (426,972,729,344 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk3s3 Mount Point: /Volumes/MachFive Content: Apple_HFS |
What did you change recently on the iMac?
Is automatic updated disabled? Are all those optimizations done? Things like having spotlight indexing turned on can appear to create sudden problems for things that otherwise seemed to work. When you tried with plugins removed did you remove both the RTAS and AAX plugins from their two separate folders? If not try that again. Also try disconnecting the sample drive and just run with the audio/session drive connected. What are all the settings on your Pro Tools playback engine dialog panel? The Playback engine itself (want to make sure you are not trying to use aggregate IO) and all the others... Scan your audio/session drive for permission and hard errors. You are using the symphony over USB? The latest drivers are installed? Darryl |
"What did you change recently on the iMac?"
Everything was working one day. Made no changes, next day the problem started. "Is automatic updated disabled?" What/where is this? "Are all those optimizations done? Things like having spotlight indexing turned on can appear to create sudden problems for things that otherwise seemed to work." Can't find the on/off for spotlight indexing "When you tried with plugins removed did you remove both the RTAS and AAX plugins from their two separate folders? If not try that again." Tried that without success "Also try disconnecting the sample drive and just run with the audio/session drive connected." Tried that without success What are all the settings on your Pro Tools playback engine dialog panel? The Playback engine itself (want to make sure you are not trying to use aggregate IO) and all the others... Symphony I/O engine chosen H/W buffer 512 (have tried others) Host proc: 7 CPU: 80 to 95% Delay compensation: none Plug-in streaming buffer Level 2 "Scan your audio/session drive for permission and hard errors." I don't know how to look for them You are using the symphony over USB? The latest drivers are installed? Yes, latest drivers installed, plus, remember everything worked, then next day w no changes it suddenly stopped working. Thanks for your help Darryl |
Digital distortion begins and persists - PT9 and M-audio 2626 | jduvick | macOS | 2 | 11-04-2012 01:07 PM |
Nasty digital distortion in copied audio files | digidesigner | Pro Tools TDM Systems (Win) | 8 | 11-08-2011 12:07 AM |
Robotic Digital Distortion when recording voice! Please help! | Roboteknic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-08-2011 07:29 PM |
MBOX Digital Distortion on Basic Audio Track Record | Tony J | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 03-31-2003 04:12 AM |
Software to detect digital distortion peaks in audio files | seman | General Discussion | 1 | 02-24-1999 12:50 AM |
