Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-30-2020, 10:12 AM
lampmusic lampmusic is offline
Default Graphic freeze on playback
New macbook pro 16 inch 32G ram / I9 / 2.3
OS 10.15.4 (what it came with)
PT 2020.3.0
No apparent problem with audio playback, but graphics appears to freeze every 5 seconds or so on playback. When this happens the counter freezes and and also the cursor in the edit window freezes.
I'm also getting beach balls when doing anything in PT like looking at preferences
2 audio files no plug ins.
Changing the buffer doesn't seem to have any effect on this.
Sorry if this has already been covered.
Running Pro Tools 2021.12
Main System 2020 M1 Macbook pro 13 inch / 16MB Ram / 1TB SSD / Big Sur
Future System 2021 14inch M1 Pro / 16MB Ram / 512 / Monterrey
Old 05-30-2020, 10:29 AM
jes's Avatar
jes jes is offline
Default Re: Graphic freeze on playback
Same here, 2020.5, Mac OS, I had thought it might be the ProTools update, so I reinstalled 2020.3, but same issue.
However, there was also a recent Mac OS security update, though I did the security update two days ago and didn't notice this behavior until today:
https://support.apple.com/en-us/HT211170
I'm on 10.13.6 so that might narrow it down to some of these fixes listed in there?
http://www.jonathansegel.com
Mac Pro 5,1 3.06ghz 64GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2022.10
UAD-2 Apollo Quad, PCIE and Satellite
Old 05-30-2020, 10:33 AM
trashing preferences so far seems to clear it up so far. I'll let you know if it changes
Old 05-30-2020, 11:18 AM
sounds a lot like another thread that recommends turning network off(to the outside) due to some odd iLok issue).
Old 05-30-2020, 11:31 AM
johan2006 johan2006 is offline
I have the same issue. Done all the usual like trash prefs, reinstalled, removed 3rdparty plugs... but it's still there. Turning off the network doesn't seem to make any difference. It gets better for 20sec and then the problem is back. Unusable, currently PT is a virtual door stop......
Presumably Ilok is the problem as I updated to 5.2.1 yesterday. Did remove and reinstall but....
Vid here: https://www.youtube.com/watch?v=vEGZ...ature=youtu.be
Old 05-30-2020, 12:27 PM
TaylorAudio's Avatar
TaylorAudio TaylorAudio is offline
Yes, this is exactly what I'm experiencing johan2006 - thanks for posting the video!
It's the first time I've used ProTools in several weeks since I've been giving Reaper a true trial run. This certainly put a crack in my rose-colored lenses! Glad I have a perpetual license because at this rate I may stop renewing my support plan.
iMac (Retina 5K, 27-inch, Late 2014) 4 GHz Intel Core i7
16G 1600 MHz DDR3 RAM
OSX 10.10
UA Apollo - Thunderbolt
Pro Tools 11.3
Old 05-30-2020, 12:38 PM
R0b M R0b M is offline
I'm having the same problem. It's been driving me crazy all morning. I thought it was only on my system.
Old 05-30-2020, 01:08 PM
jeff markham's Avatar
jeff markham jeff markham is offline
It's a bit worse than the graphics freezing. If you're recording MIDI, it freezes at the time when the GUI stutters.
Turning off the network does make it much better.
This is a serious bug.
Old 05-30-2020, 01:27 PM
FWIW (and AFAIK), the 2020.5 update seemed to squelch it for me. Will report back here if I run into it again, although like I said I'm spending my time mostly in Reaper lately.
OSX 10.10
Pro Tools 11.3
Old 05-30-2020, 02:49 PM
mjjohnson mjjohnson is offline
I'm having the same problem. It just suddenly started today. I've tried everything I can think of, but the problem still persists. I'm running Mojave.
Makes PT almost unusable at the moment, which is just awesome since I have critical projects to complete this weekend.
High Sierra graphic freeze reichman macOS 2 10-02-2018 01:03 PM
Pro Tools 10 HD (Cursor Freeze/Playback Freeze) vinlance Pro Tools 10 1 07-13-2013 11:40 AM
Fixed: Intermittent Graphic Freeze When Using Pro Tools crizdee Pro Tools TDM Systems (Mac) 4 10-03-2007 07:25 AM
Automation edits during playback crashes and graphic freezes Chris A Pro Tools TDM Systems (Mac) 0 08-12-2007 10:27 PM
graphic freeze...all gone?? ThomasPMusic Pro Tools TDM Systems (Mac) 20 03-30-2007 09:53 PM
