Artist control loosing connection
Hello,
My artist control keeps loosing connection. It either looses connection and displays the avid logo, or sometimes, rarely, it completely hangs and I have to remove the power cable and put it in again. Sometimes EuCon sees the unit as available but doesn't use it as seen on the picture. I'm on OSX 10.13.4 EuCon version 18.3.0.244 For now the artist controller is directly connected to ethernet1 port on my macPro. I'm planning to add x2 artist mix, using a switch, but for now that's my setup. Ethernet1 is on the top of the connection list as described in the Avid Installation instructions. Any idea how to troubleshoot the problem? Thanks Alex |
Re: Artist control loosing connection
I would love to know how to solve this issue! I've got an MC, 2 Mix & a Transport. I average 3 to 4 dropouts per 4 to 6 hr session!
In my case, they'll either flash, like there was a power surge, and go to the logo, or much more often ( and way more annoying), it just stops working! You'll be totally "in the zone" and you'll select some simple function, lime Clear Solo and nothing happens. Hit it again? Same result. Now you know it's dropped the connection, total buzz kill! You restart Eucon and it fires right back up but these 25 to 30 second interuptions for this kind of crap is really irritating! |
Did you do a firmware update through the EuControl app? Can you see what firmware you're running in the software?
I'm running 2 Artist Mixes, and Artist Control, and the Control App on my ipad with no issues at all. Also, make sure wifi is off and try making the devices connect with a static IP instead of dynamic. This has always seemed more stable for me. |
I'm running the latest firmware:
MC Control current version: 1.3.7.0 already at version: 1.3.7.0, won't upgrade. Static IPs are assigned to the interfaces. I also changed ethernet cable, just in case. I kindly request to get some official support from Avid. Alex |
I would check the power supply first.
Hello,
I'm Pascal from France I exactly have the same trouble than and for many years. Every thing is updated (Mac OS, Eucon, Logic pro, ...) and the time ... My Artist Control consol is connected directly to the mac by a static IP adress with a new crossover cable without anything else. The artist control can work with Logic pro several minutes or even hours and suddenly ... or not ... the console freezes and in Eucon My Artist Control deseappears. The only one solution is to switch off every thing and to restart. The problem exists only with Logic Pro. The artist Control normally reacts with every other soft. I also already try to trash preferences ... I red many things to do in forums but I'm now lost ... to be honnest ... Thank you very much in advance if someone had any idea. Musically and regards, Pascal |
Pacmac. No need to bump three threads with the same issue and post.
Try one and keep track of the info there. Sent from my iPhone using Tapatalk |
Thank you for your helping. The Power supply ? Not yet. Do you really think it could a potential root cause ? Why not ? I’m ready to try everything at this level ! I can change the power strip to try... Thank’s Pascal |
WHY does Artist MC Control keep dropping the connection? | KeyplayerG | Artist Series | 7 | 01-04-2022 03:23 AM |
Artist Control connection issues | GreenWire | Artist Series | 3 | 07-22-2015 11:54 PM |
Artist Control v2 losing connection with PT 10 (Mac) | Trazan | Artist Series | 5 | 05-22-2014 12:53 AM |
Artist Control / Ethernet Connection and Noise Problems | lberrios1962 | Artist Series | 8 | 05-04-2012 08:20 AM |
MC Control & 2 MC Mix's loosing connection to PT9 | RuffinMedia | Artist Series | 2 | 01-13-2011 01:14 AM |
