Old 08-28-2020, 02:50 AM
crizdee's Avatar
crizdee crizdee is offline
Default How are you navigating the mix window... left-right on big mixes
Just wondered if ive missed a trick somewhere. as i have up till now been using the scroll wheel + shift to move left or right to navigate big mixes. but since a fresh install on Mavericks my trackman trackball isn't doing this successfully. works fine in everything else just not PT and specificall the mix window.
My only other method at the moment is to grab the grey bar at the bottom of the page to go left right. Is there a shortcut for doing this? or any other way to navigate left right.
Even on my D Command i can't see any way to do this
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-28-2020, 07:19 AM
Default Re: How are you navigating the mix window... left-right on big mixes
option-page up/down, also option-home/end
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 08-28-2020, 10:55 AM
Folder tracks are great for large sessions
Old 08-28-2020, 03:55 PM
cwsand's Avatar
cwsand cwsand is offline
Yes - I thought it would be some feature I'd never use but now I can't live without it!
As far as the OP - not sure what's going on as I use the scroll wheel the same way to pan horizontally.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Navigating The Relink Window . . priorytools Tips & Tricks 1 08-28-2020 02:56 PM
Score window not showing left hand notes above middle C dannydog Tips & Tricks 1 02-16-2018 05:29 AM
Edit Window Upper Left Hand Corner - What Is This? foxes Pro Tools 12 9 04-26-2016 05:51 PM
Navigating in Mix Window jschmidtiii macOS 20 04-08-2013 08:35 AM
PT8 : Adjusting the Memory location window Left - Right sakman07 Pro Tools TDM Systems (Mac) 1 04-11-2009 03:30 PM
