Old 09-16-2020, 08:41 PM
reflekshun reflekshun is offline
Default Re: Is this normal performance for Artist Mix?
Originally Posted by EddieJones View Post
Do you have any other controller enabled in Logic ?
No other controllers are set up, or connected to Logic.
This behavior is happening in Pro Tools too which also doesn't have any other controllers setup or connected to it.
Old 09-16-2020, 08:45 PM
EddieJones's Avatar
I can't remember...Have you done a full uninstall? Using the installer uncheck all the Apps and also check remove all prefs. Restart and reinstall.
Old 09-16-2020, 09:15 PM
I'm pretty sure this is from a fresh install after a full uninstall, but I'll try this again tomorrow and get back to you.
Old 09-17-2020, 05:40 PM
I've uninstalled, checked removed prefs, re-installed. Still same behavior.
I also installed Avid Control on my phone and that is a lot smoother over wifi. Seems like it might be a hardware issue, but I'm not 100% sure to be honest.
Old 09-17-2020, 06:19 PM
EddieJones's Avatar
The next thing I would do is try a new network config on the mac. Watch this and try it. You will need to reboot after for EUCON to be OK. You can always switch back to the original. https://www.youtube.com/watch?v=tj5a...el=TechCoreDuo
  #16
Old 09-17-2020, 06:49 PM
Thanks I'll be back at it tomorrow and let you know how it goes
  #17
Old 09-22-2020, 02:32 PM
Sorry, busy late last week but I tried this today, and no change in behavior.
I'm starting to get the feeling it is a hardware based problem, I can't say for sure because I'm not an expert on the insides of this thing!
  #18
Old 09-23-2020, 09:43 AM
EddieJones's Avatar
Two more tings to try. Turn WiFi of on the Mac and restart and test. If that doesnt change things, do you have a router or switch you can plug the Mac and Mix into ?
  #19
Old 09-23-2020, 01:06 PM
Thanks, tried the wifi off & restart, that didn't change things.
I don't have a dedicated router / switch - only the modem router from Xfinity, would that work for this?
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Artist Chat window in Avid Artist Community taylor4814 Pro Tools 2018 0 01-25-2017 06:30 AM
2 avid artist mixes and one artist control V2 for sale Brandonx1 Buy & Sell 2 03-21-2016 09:55 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
>>poor MBox performance! is this normal? megahurt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-17-2003 11:48 AM
