Old 01-23-2012, 10:57 PM
tengai tengai is offline
Default Poor sound quality with Protools 10
Hello
I have Protools 10 installed on my Windows 7 64 connected via USB to my Eleven Rack.
When I attempt to record a guitar track with protools and play it back the sound quality is terrible. It sounds nothing like the high quality sound that was played with I recorded the track.
I've installed the latest Avid USB driver 1.0.11 and no luck.
I also have EZDrummer and playing the drum samples through the Eleven Rack have a static crackling sound at the end of the drum sample.
Does anyone have any idea why I'm not able to play high quality sounds from my laptop through the eleven rack?
Are there other drivers that need to be updated?
I have a pair of Focal 65 monitors.
Thanks,
Patrick
Old 01-24-2012, 05:41 AM
DAR Fritz DAR Fritz is offline
Default Re: Poor sound quality with Protools 10
You might try putting your project on an external Firewire hard drive if you're not already, or at least make sure you have a lot of extra room on your laptop drive. I had the same problem with my Macbook using Logic and it helped. I believe PT recommends using an external Firewire drive.
Old 01-24-2012, 07:16 AM
Might also check 11r in the control panel and see what it's clocking source is. Should be set to internal.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-24-2012, 10:01 AM
Yes, the clock source is set to "Internal"
Old 01-24-2012, 01:17 PM
Benoni's Avatar
Benoni Benoni is offline
Avid recommends you record to an additional NON-OS drive. Not necessarily an External or firewire. The best performance comes from another internal HDD. For External HDD, then E-SATA provides the best performance.
For a while Avid was saying Windows 7 users should not use Firewire, but instead opt for USB 2.0 drives.
But the underlying message it true. You should be recording/playing back from a non-OS hard drive. Not a partition of the physical drive the OS is installed on, but a physically separate hard drive.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 01-24-2012, 09:51 PM
The problem was the USB cable that came with the Eleven Rack.
Used a higher quality cable and the sound is great.
Old 01-25-2012, 06:04 PM
sorcerer27 sorcerer27 is offline
Wow, another bad USB cable.
Poor Sound Quality when Playback? thelethalkid Pro Tools M-Powered (Win) 2 01-23-2011 08:19 PM
Poor Quality Bounces 2hip2b4real 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 43 12-04-2009 02:19 PM
SM57 Poor Quality Recording Matt Darcy General Discussion 22 02-07-2009 07:14 PM
poor sound quality = 192 problem? calling DigiTechSupt... Rader Ranch Pro Tools TDM Systems (Mac) 9 03-11-2008 06:15 PM
poor quicktime quality player maquisar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-27-2006 02:13 AM
