Old 09-08-2008, 06:31 PM
playgirist playgirist is offline
Post Need help with Mbox2 Mini setup.
I have Mbox2 Mini and trying to use Keystation 88es as a MIDI controller.
I figured out that there isn't any MIDI port on Mbox2 Mini. Therefore, I just connected Keystation88es to my computer since there was a USB MIDI in/out. Is this setup correct, without having the MIDI controller connected directly to Mbox2 Mini?
With the above setup, I tried playing my keyboard on PT. However, I couldn't hear any sounds. Rather, I could see the signals in the fader, in the mix window. I don't have a monitor speaker so I plugged in my computer speaker (Apple Pro Speaker) using a 1/4 inch TRS adapter. Do I need to get the monitor speakers to hear the sounds? Also, is there a way to use Mbox2 Mini as if it were a default soundcard? I need help :/
Old 09-09-2008, 08:58 AM
DigiTechSupt's Avatar
Default Re: Need help with Mbox2 Mini setup.
That's correct.
What are you using to play back the MIDI data? MIDI is just data - it's not the sound itself, so you need to use a softare synth or sampler or and external hardware synth to hear anything.
Avid Audio Tech Support
Support FAQ
Need desperate help with initial setup of PT8 and Mbox2 Mini on Mac greensombrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-24-2010 06:23 PM
Newbie with MBox2 Mini - Setup MIDI Ctrl sloman61 MIDI 4 02-15-2010 01:45 PM
Setup for PT LE Mbox2 Mini Win XP system karkkola 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-13-2010 11:49 AM
MBox2 Mini - Upgrade Hardware to MBox2 Pro gjmunro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-14-2009 01:09 AM
Any Mbox2 Mini/MAC Mini Intel Users? Need help with Reason Mbox2digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2007 07:37 AM
