Old 08-25-2017, 09:26 PM
tbond tbond is offline
Default iLok upgrade wont let me into pro tools
My Pro Tools will not open. I get a message that I must upgrade my ilock, see attachment. I did this and still get the same message. Ilock's help says to refer to Avid. My Pro Tools is 11.3.1 not HD. Any help would sure be appreciated. Thanks!!ilock.JPG
Old 08-25-2017, 10:00 PM
Default Re: ilock upgrade wont let me into pro tools
Is this a new problem on a system that was working before, or has it not worked ever? Assuming it worked before, log onto your iLok account. If your iLok shows up and you can see your licenses, run the re-sync function in the iLok manager. If your iLok doesn't appear, pull it and plug it back in, or try another USB port.
If its not lighting up blue, than its not being seen by the computer(which we have zero information about)
Old 08-25-2017, 10:43 PM
Yes it has worked excellent from 2013 until last week on the same computer. I tried the re-sync and still the same messages. There is a blue light on the ilock and I can see the license in the account manager. My current version of iLock is 2.4.3.756 and I am using Windows 7 Professional. Really confused...
Old 08-26-2017, 06:16 AM
Are you plugging the iLok into the same USB port as you have been in the past? Windows gets weirded out when you move any USB peripheral from the original port when it was installed to another port. And make sure you've turned off any power savings measures in Windows Control Panel.
Jack
QAPLA!
Old 08-26-2017, 10:48 AM
Thanks for responding. Yes, same port, I checked the settings in the control panel and it is set to "high performance" like it always has been. I did notice that when I look at the drives in my menu the iLok does not show even though it is completely functional when I open iLok manager. Blue light works and I can move around on it.
Old 08-26-2017, 11:37 AM
The iLok dongle is NOT a drive so it's natural that it won't show in any menu. What do you mean by 'I can move around on it'? 'High performance' setting doesn't really mean much. You have to go specifically to the Windows Control Panel entries that refer to the USB ports and disable power savings there.
Jack
QAPLA!
Old 08-26-2017, 03:38 PM
By move around, I can re-sync and move licenses ie hidden etc. on the iLok. The iLok seems to be working fine.
I have checked all USB Hubs in the control panel and all "Allow the computer to turn off this device to save power" boxes were and are unchecked. Device Status claims that all devices and ports are working properly.
I still don't get why the upgrade iLok notice keeps popping up.
Old 08-26-2017, 03:45 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: iLok upgrade wont let me into pro tools
You mentioned updating iLok but later said you have 2.4.3.756 installed which is an older version.
iLok License Manager 3.1.6 was released last March and should fix this for you.
Please see avid.force.com/pkb/articles/Error_Message/Authorization-exception-when-launching-Pro-Tools
Old 08-26-2017, 05:00 PM
You are correct that is the version I have. When I attempted to upgrade to 3.1.7. this is the message I got from iLok:
Due to Microsoft bugs where some Windows 7 systems are unable to update, we've changed our installer to no longer require any Windows 7 updates.
As you can see this whole thing is in a circular mode. I thought someone else would have experienced this. I'll try the 3.1.6. Thanks!!
Old 08-26-2017, 05:07 PM
jeffro's Avatar
That info just means that previous installers required a specific Win7 patch. iLok modified their installer to not require that patch.
Installing the updated iLM should solve the problem on your system.
Pro Tools wont load after upgrade!! Help!! Playersly Pro Tools 12 3 02-12-2017 08:25 AM
Pro Tools 11 Upgrade - ilok Server [RESOLVED] Po-Ethix Windows 4 07-18-2014 12:52 PM
Pro Tools Express wont see iLok Parisstudio Pro Tools Express on Windows 9 12-10-2013 02:04 PM
Pro tools 8.04cs2 upgrade, Pro tools wont launch! Please help me! ohyoshimi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-20-2011 12:15 AM
