Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 08-09-2016, 12:19 AM
waynekhin waynekhin is offline
Default Possible to control 5.1 Master fader with Pro Tools | Quartet main volume knot?
I just setup the Pro Tools | Quartet with Pro Tools 11 HD. I would like to know if it is possible to control the 5.1 Master with the main knot on the Pro Tools | Quartet? For now, it seems to be controlling the Stereo output from 1&2 main outputs only. Need help/advice from someone
Thank you.
Wayne Khin
www.homestudio.com.sg
www.homestudiomusic.com
Old 08-09-2016, 06:20 AM
Drew Mazurek's Avatar
Default Re: Possible to control 5.1 Master fader with Pro Tools | Quartet main volume knot?
If it's anything like my symphony you would need to change this in the Apogee Maestro app
www.drewmazurek.com
Old 08-09-2016, 09:49 PM
Thank you Drew. It seems like the Apogee Maestro app supports the products from Apogee, not the Pro Tools | Quartet made for Avid. I will still download and try my luck though .
Thanks agin.
Wayne Khin
Old 08-09-2016, 10:18 PM
Thanks agin.
Hi Drew, finally I found out that Pro Tools | Quartet version comes with additional Software called "Pro Tools IO Control". From there I am able to set the main volume knot to control either Stereo or 5.1 monitors.
Thanks agin.
Wayne Khin
Pro Tools Mackie Control. master fader?? Kerochan Pro Tools 12 2 07-05-2016 01:37 AM
Pro Control Main Unit and Fader Pack MIKEROPHONICS Buy & Sell 4 02-22-2016 12:51 PM
Quartet stereo hardware to PT 11 master fader sankstone Pro Tools 11 3 04-21-2015 05:00 PM
Is delay compensation necessary for Master Fader on Main Outs? WinTaper Pro Tools 10 1 02-19-2014 06:57 AM
Plugins on Master Fader or Main Mixdown Track studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-20-2007 01:02 PM
