Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 08-06-2016, 08:11 PM
reichman's Avatar
reichman reichman is offline
Default iPad Pro 9.7" VS. iPad Air 2 ?
Is there a compelling technical reason that Pro Tools | Control would run better on the newer iPad? Specs are pretty similar on the Apple website. For the purposes of Pro Tools, everything is the same except the A9 vs A8 processor.
Firsthand experiences? Thoughts?
Thanks!
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 08-07-2016, 11:46 PM
crustn crustn is offline
Default Re: iPad Pro 9.7" VS. iPad Air 2 ?
You won't see any difference. The app doesn't need much processing power. It even works great with the old iPad 2. Just be sure to have a high bandwidth and stable wifi connection. If not, the app will be sluggish.
with iPad Pro 12.9" resolution problems? Picio Avid Scorch (iOS) Forum 0 07-13-2016 09:40 AM
How do you hardwire connect both Dock and iPad" Cherub1 Pro Tools 12 0 06-04-2016 06:07 PM
"Instrument names reappear after changing fonts on iPad Scorch" jccmusic Avid Scorch (iOS) Forum 1 12-02-2011 03:03 AM
Will the ipad?".......... barters81 General Discussion 4 04-13-2010 01:06 AM
