upgrading structure?
I have pro tools 9 and it came with structure free. Can I upgrade to structure? On the website there are various upgrade downloads for it. Which one do I use? Is it the $49 one, or one of the other ones? Thanks for the help guys.
Re: upgrading structure?
There are 3 versions of structure: Free, LE, and the full version
You can't upgrade to the full version from free, you have to own it already. If you own any of the AIR instruments (strike, velvet, transfuser, hybrid, Structure LE) you can upgrade to the PTIEP, which includes full version of Structure, for $199. Your best deal would be to try and buy any one of those used plugins and upgrade to PTIEP. Do a search on ebay for "avid structure" and you'll see several sales of Structure LE for $50 or so, then you could upgrade I've never bought a used plugin, though, so you need to make sure that the license ends up in your name correctly in order to use the upgrade. Maybe someone else could explain how that process works...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Structure Free unable to load homemade files from Structure 1.0 | tuchel | Virtual Instruments | 0 | 04-26-2013 09:10 AM |
upgrading to PT10 with PTIEP regarding Structure | Marc81 | macOS | 8 | 10-24-2011 06:05 PM |
Problem upgrading Structure Essential | justNotz | Pro Tools M-Powered (Mac) | 3 | 02-10-2011 03:25 AM |
The updater for Structure on Windows fails to locate and update Structure LE | Top Jimmy | Virtual Instruments | 23 | 07-27-2010 08:40 PM |
