Old 05-06-2008, 07:34 PM
luris luris is offline
Default \'Create Click Track\', can it play the same note?
With the 'create click track' command in the 'tracks' menu, is there a way to make it click with one consistent tone? No change for the downbeats?
I know via midi and using the plug-in 'click' you can.
I find the 'create click track' very quick and easy but in some situations need to have a steady pulse with no change in note to mark downbeat.
It helps me work with different time signatures as well as taking timings for commercials.
I can't find where or if there is a way to do this.
Thanks
Old 05-06-2008, 08:35 PM
Drew Mazurek's Avatar
Default Re: \'Create Click Track\', can it play the same note?
Marimba 2 is unaccented. As is one of the cowbells I think.
www.drewmazurek.com
Old 05-06-2008, 09:12 PM
Perfect.
Thank you
Old 05-06-2008, 10:13 PM
JGuth JGuth is offline
The accents are set in the setup/click countoff menu where you set a velocity for downbeats and other beats, just set them equal.
Old 05-07-2008, 06:03 AM
Some of them use a different sound for accented and unaccented.
www.drewmazurek.com
How to create click track - PT5.2.1 - Digi001 VincentAlexander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-27-2015 05:47 PM
strike will not play a midi note on a track Filmusic Virtual Instruments 2 07-30-2010 01:48 AM
How do I create a Click Track?!!! AndyA1979 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-08-2006 03:57 PM
CLICK TRACK-How to create? tikboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-16-2004 05:49 AM
