Old 10-12-2011, 02:49 PM
seva seva is offline
Question Waveforms half-height. Can't fix.
PT 8.1.1 HD TDM, OS10.6.7. recently the waveforms simply display at half-height, like they've been reduced by 6dB, although they play correctly (something i know was at 0dBFS still meters correctly).
i've used Pref & Database helper. restart. reinstall. updated to 8.1.1 (from 8.1cs1) nothing changes it.
can't find any other entry anywhere on DUC. anyone have an idea here?
Old 10-12-2011, 02:58 PM
plastikman plastikman is offline
Default Re: Waveforms half-height. Can't fix.
Well, considering all the troubleshooting it looks like you did, I'm sure it's not something this simple, but.... double-clicking the zoom tool icon resets zoom views to default. I'm guessing you did that, just throwing it out there. Otherwise, I'm not sure.
Originally Posted by Dizzi45Z View Post
Pro Tools doesn't ever not cease to not amaze me.
anothercolour anothercolour is offline
Maybe you have selected Rectified waveform view under the View > Waveforms menu option.
Old 10-26-2011, 12:32 PM
yep, i've used PT since v1. doubleclick to restore zoom level. not rectified. these are literally 1/2 height. when we record they are correct. as soon as we hit Stop, the waveform overview drops in height. i exported the session to PT 5.1, opened it on my vintage PT 5.1.2 TDM system. it rebuilt waveform overviews and they were all correct. so it's this system for sure....
Old 10-26-2011, 12:41 PM
bashville bashville is offline
Does the actual wave height adjust button change anything? I wonder if any of that could have been saved in a memory location or window configuration....
HD Ultimate (Native), PT2019.5, 192, 3.2 Quad MacPro 5,1, 16 Gig, Sierra
Old 10-26-2011, 02:31 PM
Firechild Firechild is offline
Why is Pro Tools default waveform size not 1:1 ?
I mean if you have an normalized waveform it should fit perfectly reaching top and bottom on the "peak position" only.
Now the deafult size makes your audio look much "hotter" than it actually is.
HD3 PCIe, HD I/O , HD10.3.10, Mac Pro 6 core , 24 GB RAM , GTX285 , 10.8.5 , UAD-2 Quad Satellite , ATC SCM25A Pro with ADAM Sub 12.
Old 11-02-2011, 12:46 PM
the wave height buttons do work, but a full scale signal shows only 1/2 way up. sheesh! i think i need a full re-install... must be a corrupt .dll or something.
as for default settings, i agree it should be 100%, because it's the pro way to go. on the other hand. it might keep some of my clients from clipping!
track height jknourse Windows 1 07-18-2012 03:06 PM
Waveform height Stig Eliassen ICON & C|24 14 10-30-2011 03:25 PM
Default wav height Rob_A Windows 2 08-04-2011 10:56 AM
How to get tracks the same height? dubaifox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-22-2007 04:07 PM
Half-Height Fire Wire Card? Sharritan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-29-2004 07:56 AM
