Old 03-04-2004, 10:08 AM
Locash Locash is offline
Default slow down record effect
i am trying to have the end of this song slow down to a complete stop....like a record slowing down to stopping effect. i dont have the d-fi plugins. im on osx.2 and PT 6.2. Is there any way else to do this?
thanks
Old 03-04-2004, 10:41 AM
martian martian is offline
Default Re: slow down record effect
think dsound on os 9 could do that.
or you could send me a cheque along with the file /where/when/duration
Old 03-04-2004, 10:49 AM
GORILLA GORILLA is offline
Will the TCE plug-in do that for you?
Do you have -LIVE-?
And isn't D-Fi a part of PTLE 6?
I'm soooo confused
I did that exact same effect last November for someone ...and I can not remember...what the HELL I used for it.
METAL LABS
Old 03-04-2004, 10:59 AM
mindnoise mindnoise is offline
check out the pluggo OSX thread by Simon666
and get PeRColate pluggos, Harm-Z is what you most probably want.
regs
last: PT11.3.1
Old 03-04-2004, 11:05 AM
Nathan B Nathan B is offline
I've done it before with the Time Comp, expansion. It takes a LOT of playing around. But at least you don't have to fork out for an plugin or give some joker a cheque.
It's a while since I tried it, but you need to seperate the section you want to slow down. Then seperate that region into equal parts.
For example: split 20 seconds into ten equal parts of 2 sec. Then use the plugin, and change each region one at a time, making the next slightly longer then the previous.
For example:
First region 2sec change to 2.25sec
Second region 2sec change to 2.5sec
Third region 2sec change to 2.75sec
And so on...
On the last region you could try adding some kind of dissortion, to create that 'grinding to a holt' sound.
You'll most likly have to try this out at least twice before you get something that works. There maybe a better way of doing this, that doesn't involve money. In which case, I'd be very interested myself.
Hope this helps
Nath
Old 03-04-2004, 11:14 AM
see my post above
regs
last: PT11.3.1
Old 03-04-2004, 11:33 AM
SCD SCD is offline
If you have any outboard gear to record to use the audio scrub tool in PT going from left to right by hand gradualy slowing down till you stop. Then bring it back in PT & there you go. FREE!
Cheers. Where do I go?
Old 03-04-2004, 12:51 PM
AverageJoe AverageJoe is offline
The vari-fi plug in does this exact thing.
...oh but I think that's part of the d-fi plugs which you said you don't have!!! sorry if that's the case!
Old 03-05-2004, 02:12 AM
orage orage is offline
Nope. Wouldn't that be nice though???
Personally, I'd either use Live or Pitch n' Time to do this effect...I have Vari-Fi as well, but like the higher degree of control offered by these...
Guess you could also pick up Scratch or Final Scratch and get an even closer emulation...
Paul Peterson
Sound Director
The Old Globe
San Diego, CA
Can I record with insert effect? cuttothebeat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 06-15-2017 10:38 AM
Tempo change/slow down effect how to?? ostrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-02-2008 05:17 PM
How to Get the "Scratched Record" effect? dts.music Tips & Tricks 8 02-03-2007 09:46 AM
How to do "slow pitch down" effect in PT? emde 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-14-2006 01:34 PM
Record Stop Effect snoopy Tips & Tricks 7 11-01-2002 05:02 PM
