Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 07-27-2019, 06:55 PM
Nick Namnone Nick Namnone is offline
Default Eucon won't launch
Running Macbook Pro OS 10.14.5 Mojave. Newly installed Pro Tools 2019.5
I had trouble with PT Control no longer connecting with High Sierra.
uninstalled old version of Eucon and downloaded EUCON_WorkstationUnifiedInstallMac_19_5_1_44_10592 9_
It crashes without ever loading. Tried several times. I get a crash report right away.
Any suggestions? Preferences to remove? Some incompatibility I am missing?
Old 07-31-2019, 09:28 PM
EddieJones's Avatar
Default Re: Eucon won't launch
Its not clear what OS you are on? But run the installer and select uninstall all and also check remove prefs. After reboot and reinstall EuControl.
Old 08-01-2019, 10:42 AM
thanks for getting back to me. Sorry if I was unclear. I am currently running Mac OS Mojave 10.14.5. on a 15" MacBook Pro. proc 3.1GHz intel core 7. 16BG Ram.
I had been running on High Sierra and I couldn't get my ipad to connect with Pro Tools. I upgraded to Mojave and installed what I think are the latest drivers. Workstation 19.5.1.
After upgrading to Mojave and installing 19.5.1 when I started the laptop Eucontrol would launch and then immediately crash. I ran the uninstaller and redownloaded 19.5.1 and tried again. Same result.
I uninstalled again and tried workstation 18.3.0. Same result. Tried a couple of times uninstalling every time.
I then went back to Eucontrol 3.7. Same issue.
Something is preventing Eucontrol from working/even loading.
Any ideas about what I might look for to clean out or add?
Thanks again for the help.
Old 08-01-2019, 10:55 AM
I think I may have figured out the Eucon crash problem. I need both Eucon 3.7 and the unified installer installed together. (RTM). I was originally just having trouble getting PT control to work and likely uninstalled Eu 3.7 before installing 19.5
Don't have the ipad with me to check to see if it connects. Thanks again for the help.
Old 08-01-2019, 11:00 AM
EddieJones's Avatar
Having them installed together is not recommended at all and will definitely cause issues. Have you added EuControl to the new Security feature in mojave? It should have asked.
Old 08-01-2019, 12:57 PM
I added it accessibility. Is there something else?
I have uninstalled EuControl and reinstalled 19.5.1 and it is no longer crashing on launch. I will see if the iPad connects with it later.
Not sure why it was crashing immediately but after I installed 19.5.1 and then 3.7 it started working.
Either way launches now.
Thanks again
Old 08-01-2019, 01:23 PM
EddieJones's Avatar
You will need to download the new version today 19.7 to get the iPad to work (if that updated too)
Old 08-01-2019, 03:28 PM
Great. I will do that.
thanks
Old 08-02-2019, 07:06 PM
seems to be working now. great. thanks.
Old 10-16-2019, 03:04 AM
moranibus moranibus is offline
Hi, I have a similar Problem. PTC won't launch since yesterday, respectively hardly ever (and crashes, which is completely new). iOS 12.4.2, macOS 10.14.6, Eucon 19.9.1.17. Avid Transport works without any problems. Did a uninstall but without the prefs. They don't erase my personal user sets, right? Thanks and best.
PT Ultimate, Avid S3, Avid Artist Transport, Pro Tools Control
Eucon 3.6.1 - eMix 6.1.0 - No Eucon channel meters Rpro System 5 14 08-04-2017 11:20 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Pro Tools | S3 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 0 08-05-2015 02:09 AM
