Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 06-28-2019, 07:03 AM
Ale Ale is offline
Default PTControl 19.5.1 does not change open plugins as it was
Hi there
Since i updated to 19.5 or 19.5.1 the software does not work as it has been the last years.
I open an EQ via PTControl (This still works)
In every former version i clicked into another track on the computer monitor then automatically the eq of that track was opened. This was a very nice thing as I always had the EQ of that track open. Now it just close the plug and does not open any eq on another track.
This behavior is also broken for sends and pans.
Since everything is broken the software use useless to me.
Does anyone have the same behavior?
Support could not help
Ale
2x PT HD Native 2018.12 /6/12-Core Westmere/ 48 GB / OS 10.12.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 10.4.3)
1x PT HD Native 2018.7 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002
www.tonstudio-gress.de
www.facebook.com/TonstudioGress
Old 06-28-2019, 08:25 AM
BScout BScout is offline
Default Re: PTControl 19.5.1 does not change open plugins as it was
Read the release notes for Eucontrol before installing.
There are now options. They are outlined in the release notes when new versions come out.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-30-2019, 07:04 PM
Brandonx1 Brandonx1 is offline
I agree. I really liked the way it used to work.
FYI if you attn the EQ on the bottom row of knobs, the EQ plug in will follow the pro tools track selection.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 07-03-2019, 12:35 AM
Ale Ale is offline
@Bscout
i updated a lot of apps on my ipad and i did not see that PT Control was selected for update. From then on you have no chance to use the software if you do not use the latest EUCONTROL.
There are no options that change this behavior.
@Brandonx1
What did you mean with bottom row. I only have PTControl ant no Artistmix/S3/s6...
Ale
Old 07-03-2019, 07:18 AM
Originally Posted by Ale View Post
@Brandonx1
Sorry about that. I think I just assumed you had an S3. I don't know how to do that without a S3.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 07-03-2019, 01:15 PM
The options are in Eucontrol. General page.
That is about the behaviour with plugins.
Not about installing or not installing a version of Eucontrol or the Control app. That is on you to be responsible for what is installed or not.
Old 08-22-2019, 01:25 AM
Ale Ale is offline
the latest update Eucontrol 19.7 works now as normal as there is an option now in control software
Aleto change the behavior.
How to clear meters on an iPad in PTControl? VRW Pro Tools | Control 4 12-22-2017 10:12 PM
Adding memory locations in PTControl dovwater Pro Tools | Control 1 05-31-2017 03:34 PM
Ipad PTcontrol with ethernet connection Ale Pro Tools | Control 1 02-16-2016 09:08 AM
Tempo Change window doesn't open larsongs Pro Tools 10 1 11-15-2012 06:07 AM
Tempo Change window doesn't open larsongs Pro Tools 10 0 11-15-2012 04:51 AM
