Old 09-04-2007, 02:45 PM
Camilo Orozco's Avatar
Camilo Orozco Camilo Orozco is offline
Default Click track won\'t play consistently
Hello Protoolers,
A few days ago I upgraded from my trusty PT 6.7 to PT 7.3.1cs4, I was fixing a drum session and notice inconsistenses in the rythm so I insert a loop and duplicate it a few bars to check if the drummer was bad or the click was not ok... the click was NOT CONSISTENT.
Then made a new session, juse a click track (instrument track) and an audio track, play it, and the click was not consistent.
I dont know if this is been covered, if so, please let me know where to find the solution.
Any help would be very appreciated.
My set up:
Mac G4 1.2 ghz
2 Gbytes RAM
1 drive for OS and PT and 1 drive for Audio files
OS X 10.4.9
PT HD 7.3.1 cs4
3 Process cards
The system had at least 2 years working 24/7 with OS X 10.3 and PT 6.7 without any problem!
Please Help!
Thank you.
Camilo Orozco
Like us on www.facebook.com/artedigitalestudio
www.estudiodegrabacion.com.mx
Old 09-04-2007, 11:30 PM
Ian Bodzasi Ian Bodzasi is offline
Default Re: Click track won\'t play consistently
I've seen this too...it's always a little late compared to the grid, but sometimes it's randomly ALL over the place, nowhere near the grid. I usually end up slicing up a bar of click, placing it right on the grid, and copying it across. It's a pain in the butt, but only way it seems to make it do what a click should do...
www.bodzasi.com
Old 09-05-2007, 09:11 AM
DigiTechSupt's Avatar
Have you absolutely, positively verified that all installed plug-ins are Pro Tools 7 compatible? I've seen this caused by having outdated or unauthorized plug-ins installed. You can test by removing all plug-ins except for click and stereo mixer, trashing prefs, restarting and testing again.
Avid Audio Tech Support
Support FAQ
Old 09-05-2007, 09:21 AM
Positive. It was happening to me once on a brand new rig, with nothing else installed other than the Digi plugs that went in when installing protools off a CD.
www.bodzasi.com
Old 09-05-2007, 10:19 AM
Can you give me a complete system spec, including computer model, OS version, Pro Tools version and any attached peripherals?
Support FAQ
Old 09-08-2007, 08:03 PM
It was a while ago....I think I was on a Dual 1.0 mirror drive door G4 at the time. Probably PT 7.3.1, but couldn't say for sure...I've upgraded my rig a few times over the last year, and unfortunately don't recall which one it was on...
www.bodzasi.com
Old 09-15-2007, 11:45 AM
Thank you Digi Support,
All plug-ins are 7.x compliant. I downloaded ALL of them to install them on the new system, I paid for the upgrades of everything.
No "Demo" plugins are installed, not even in the ilok, I have a separate ilok for demos, since there is no way to get rid of those licences.
Here is the list of the Hardware and Software, it is important to remark that it is the SAME system that I was using for almost 2 years with PT 6.7 and ran without any problems at all.
The only hardware that was not there when I did the new istallation was the Hard Drive where I installed the OS and PT, because I save the "old" one with the working PT 6.7 in case something wrong happend, (may be I am going back to 6.7), I got a new Hard Disk to make the new installation.
Power Mac G4 MDD
Procesor speed 1.25 Ghz
Memory: 2 GB
Bus Speed 167 Mhz
This model it is listed in the compato docs.
1 HD core plus 2 Process Cards (non Accel)
1 250 GB IDE/ATA Seagate Barracuda Hard Disk for OS X and Programs
1 250 GB IDE/ATA Western Digital Caviar for Audio
OS X 10.4.9 updated with "Combo" update.
Protools 7.3.1cs4 TDM
ProControl Main Unit with 3 Fader Packs (I notice that the firmware of all this units was updated whe first launching PT 7.3)
192 I/O with legacy Adat Bridge 24
It is important to tell you that I erase both drives (OS and Audio) completly and then did all the instalation from zero. Both drives where formated OS X Extended Journaled
I followed the instructions on the manual for the instalation, and I followed the instructions at the general troubleshooting post without any improvements.
I moved all the plugins from the Plugins folder and left only the mixer and the click plugin and there still were inconsitencies.
There is also another problem... I hear audio AFTER I STOP the playback!
I am an experienced PT user, I run the studio since Session 8 in the early 90's so I think I know what I am doing.
Please Help!!! I need my studio to work as soon as possible.
Thank you.
Camilo Orozco
Here is the plugin list (taken from the "Protools Version List") in case it is relevant, but I dont think it is plug related because I moved everything from the plugins folder and left click and mixer plugs and did not work, anyways here it is:
Fri Sep 14 11:08:39 CDT 2007
Pro Tools Version
__________________________________________
Pro Tools HD.app
7.3.1cs4, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Plug-In Versions
SonyOxfordEQ.dpm
2.52x0, Copyright 1991-2005 Sony, Oxford.
SonyOxfordInflator.dpm
1.4x0, Copyright 1991-2005 Sony, Oxford.
Access Music Indigo.dpm
7.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Amp Farm.dpm
3.10, Copyright 2006 Line 6
Analog_Channel_HD.dpm
3.1x8, Copyright 1998-2006 McDowell Signal Processing, LLC
Aphex Aural Exciter.dpm
Aphex BigBottom Pro.dpm
Auto-Tune_TDM.dpm
5.0.8, Copyright © 2007 Antares Audio Technologies
BF Essential Clip Remover.dpm
BF Essential Corr.dpm
BF Essential Meter.dpm
BF Essential Noise.dpm
BF Essential Tuner.dpm
Bruno.dpm
Chorus.dpm
Click.dpm
Cosmonaut Voice.dpm
D-Verb.dpm
DigiReWire.dpm
Dither.dpm
Drawmer Dynamics.dpm
Drumagog.dpm
1.0x0, Copyright 2006 FXpansion Audio UK Ltd..
DrumagogFL.dpm
Dynamics III.dpm
EQ III.dpm
Echo Farm.dpm
2.30, Copyright 2006 Line 6
FilterBank_HD.dpm
4.1x8, Copyright 1998-2006 McDowell Signal Processing, LLC
Flanger.dpm
Focusrite d2.dpm
Focusrite d3.dpm
Funk Logic Masterer.dpm
Invert-Duplicate.dpm
LoFi.dpm
MC2000_HD.dpm
MDW_EQ2_3B.dpm
2.0.2r44, Copyright 2007 Massenburg Design Works.
MDW_EQ2_5B.dpm
Melodyne plugin.dpm
Melodyne plugin 1.0.2.0 Copyright 1999-2006 Celemony Software GmbH
Mod Delay II.dpm
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Phoenix.dpm
2.4.3x22, Copyright 2002-2006 Crane Song Ltd.
Ping-Pong Delay.dpm
Pitch.dpm
Pultec EQH-2.dpm
Pultec EQP-1A.dpm
Pultec MEQ-5.dpm
RectiFi.dpm
Reso.dpm
Reverb One.dpm
Reverse-DC Removal.dpm
SciFi.dpm
Signal Generator.dpm
SignalTools.dpm
SoundReplacer.dpm
SoundToys
Stereo Mixer.dpm
Synchronic.dpm
TL Space.dpm
7.4, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Time Comp-Exp-Pitch Shift.dpm
Time Shift.dpm
7.3, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved.
TimeAdjuster.dpm
Trim.dpm
VariFi.dpm
VocALignASX.dpm
2.9.6, Copyright 1995-2007 SynchroArts Ltd.
VocALignPT.pdf
WaveShell-DAE 5.0.5
5.0.5, © 1991-2005, Waves Audio Ltd. All Rights Reserved.
WaveShell-DAE 5.4.5
5.4.5, © 1991-2005, Waves Audio Ltd. All Rights Reserved.
bombfactory BF76.dpm
Plug-Ins Unused Versions
Cosmonaut Voice
4.2, Copyright 1999-2004 Digidesign, A Division of Avid Technology, Inc.
Dynamics II.dpm
EQ II.dpm
Stereo Dithered Mixer.dpm
7.3.1cs3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Surround Dithered Mixer.dpm
Surround Mixer.dpm
Toolkits and Digitranslator Versions
Music Production Toolkit is not installed
DV Toolkit 2 is not installed
Digitranslator 2 is not installed
Digitranslator 1 is not installed
Sorry for the long post
Camilo Orozco
Old 09-17-2007, 10:02 AM
Now I have also problems with drawing the waveforms
When start recording the waveform draws as usual but a few seconds later... no more drawing!!, when I stop recording, PT redraws those tracks
Camilo Orozco
Is it possible to play a click without pressing play, and have it in sync.... ALowe macOS 5 06-05-2011 04:24 PM
'Create Click Track', can it play the same note? luris Pro Tools TDM Systems (Mac) 4 05-07-2008 05:03 AM
Click track out of synch PTS 7.3.1 cs4 (Only in Play back) andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-26-2007 02:41 AM
Mouse click changes play button but won't play screaminbytes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-13-2007 10:13 PM
click track play back eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-27-2005 08:49 PM
