Old 11-09-2011, 06:52 PM
JSR JSR is offline
Default PT 10 HD Installation / Lion Installation
I am about to install PT 10HD, currently running PT 9.0.5 HD, can you do a clean install (not an upgrade install) and not have to reinstall all plugins.
Also, should I do the OSX upgrade to Lion (from Snow Leopard) before or after the PT 10HD upgrade.
Thanks for any info,
Best,
JSR
Old 11-09-2011, 07:11 PM
janmuths janmuths is offline
Default Re: PT 10 HD Installation / Lion Installation
Hi there,
I'd strongly suggest a clean re-install. Update the OS via combo installers first. Repair Disk permissions. Then install PT. Repair disk permissions again. For some of your plug-ins you may be able to copy - paste from an old PT installation. Check plug in versions against the compatibility grid on the avid website.
Usually plug ins that use iLok licenses and do not require external content work after copy pasting them once you plug your iLok in.
Plug ins that require serials or challenge/response do usually require a clean re-install. That's the case for my IKMultimedia stuff for example.
Am running PT10 on Lion and no problems so far.
Hope this helps.
Cheers,
Jan
2010 Dolphin Award for Production / Engineering
AVID Certified Instructor
Neverending problems PT10.3.7 installation on Mountain Lion indrama macOS 13 10-25-2013 06:45 AM
Neverending problems PT10.3.7 installation on Mountain Lion indrama Pro Tools 10 9 10-24-2013 05:04 AM
Installation of Protools 8 LE on Macbook Pro OS Lion AmyH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-16-2012 01:17 PM
'Installation Failed' installing Pro Tools MP 8.0.2 on OS X Lion FuryMuso Pro Tools M-Powered (Mac) 3 06-03-2012 03:12 PM
Update only works on Installation...cannot perform installation on Win7 xRollinx Pro Tools M-Powered (Win) 5 02-12-2010 07:35 PM
