Old 04-11-2003, 06:35 AM
vindaloo99 vindaloo99 is offline
Default minimum memory settings?
I changed the minimum memory settings on both Pro Tools Free & DAE. Can anyone tell me what they should be so I can revert them to the default settings? Apparently they should never be changed. The program still works although I often get a DAE error on start-up and I have to reboot. Currently I have PT memory set at 260000K min, 360000K max., DAE memory at 64000K min, 96000K max
Thanks
Old 04-11-2003, 09:33 PM
M.Brane M.Brane is offline
Default Re: minimum memory settings?
DAE min size is 9838, I have my preferred set at 71838.
PTF min size 21084, my preferred is at 61162.
Your correct that you should not alter the min size. In most apps I usually up the preferred in 10MB increments until I notice no difference in performance.
HTH [img]images/icons/smile.gif[/img]
Old 04-12-2003, 05:49 AM
Thanks,
I'll make those changes. Just out of curiosity, why isn't it advisable to change the minimum memory settings?
Old 04-12-2003, 04:06 PM
You know, I honestly don't remember where I got that from, but in a search to find out I ran into this thread which has some good info on memory management.
HTML code is On
Default Minimum Memory Setting saeblee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2003 05:50 AM
Minimum memory issue clutch Pro Tools TDM Systems (Mac) 1 12-04-2002 12:12 AM
Minimum and recommended Memory after expansion PlugInJunky Pro Tools TDM Systems (Mac) 3 08-23-2002 12:22 AM
minimum memory allocation for dae/PTLE dcurran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-04-2002 09:27 AM
never change minimum required memory ?? Chris Lambrechts Pro Tools TDM Systems (Mac) 7 09-05-2000 04:31 PM
