Old 05-07-2003, 05:17 AM
saeblee saeblee is offline
Default Default Minimum Memory Setting
Can anyone tell me the default setting for MINIMUM memory allocation for Protools AND DAE? I was messing around last night changing my settings, and I accidently changed the minimum settings also. I don't need to know your preferred settings, I've already chosen those. According to digi tech support, you're not supposed to change the minimum default settings.
Thank you very much
Old 05-07-2003, 05:50 AM
where02190 where02190 is offline
Default Re: Default Minimum Memory Setting
I believe if you set the minimum to 0 and hit enter, it will reset to the default setting.
Hope this is helpful.
minimum memory settings? vindaloo99 Digidesign Hardware & Software 3 04-12-2003 04:06 PM
Minimum memory issue clutch Pro Tools TDM Systems (Mac) 1 12-04-2002 12:12 AM
Minimum and recommended Memory after expansion PlugInJunky Pro Tools TDM Systems (Mac) 3 08-23-2002 12:22 AM
minimum memory allocation for dae/PTLE dcurran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-04-2002 09:27 AM
Minimum memory required for PTLE 5.1 rusmooth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-15-2001 11:37 AM
