Old 06-03-2002, 06:02 PM
dcurran dcurran is offline
Default minimum memory allocation for dae/PTLE
mundane post - I allocated more memory to DAE and PTLE, then saw the tech support posts about "never change your minimum allocation!!!" (which I did). They suggested hitting 0 in "minimum memory", then enter and it would come up with the minium requirement that Digi allots, but it only comes up with the last value I entered, which is (apparently) much too high.
If anyone can look up numbers, I'd appreciate it.
Thanks
dc
Old 06-04-2002, 08:51 AM
Default Re: minimum memory allocation for dae/PTLE
It would be great if somebody who hasn't changed their minimum RAM allocation numbers for DAE and PT (I'm using the mBox with PT) could do a quick get info and post those two numbers - I went and changed the minium memory settings and they do not return upon hitting 0 and then enter...
thanks
dc
Old 06-04-2002, 09:22 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
You can use the following Minimum memory values for PT LE 5.1 and later:
DAE: 10026k
PT LE: 35905k
Brent
Avid Audio Tech Support
Support FAQ
Old 06-04-2002, 09:27 AM
Great! Thanks
dc
minimum memory settings? vindaloo99 Digidesign Hardware & Software 3 04-12-2003 04:06 PM
Minimum memory issue clutch Pro Tools TDM Systems (Mac) 1 12-04-2002 12:12 AM
Minimum and recommended Memory after expansion PlugInJunky Pro Tools TDM Systems (Mac) 3 08-23-2002 12:22 AM
Minimum memory required for PTLE 5.1 rusmooth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-15-2001 11:37 AM
never change minimum required memory ?? Chris Lambrechts Pro Tools TDM Systems (Mac) 7 09-05-2000 04:31 PM
