Unable to install PT -- "procedure entry point" error
I'm unable to get the Setup program started from the Pro Tools 7.4 DVD. I can see all of the files, but when Setup is chosen, I get this message:
The procedure entry point could not be located in the dynamic link library KERNEL32.dll. Pro Tools has never been installed on this machine. The target drive is a dedicated NTFS drive, prepared according to the instructions in the Mbox 2 Mini Getting Started booklet. I'd appreciate any advice offered. Here is the Sandra report: SiSoftware Sandra Computer Workgroup : UNIVAC9000 Host Name : OLD-MAIN User : Bruce V. Dries Processor Model : Intel(R) Celeron(R) CPU 2.93GHz Speed : 3GHz Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Integrated Data Cache : 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 256kB, ECC, Synchronous, ATC, 4-way, 64 byte line size, 2 lines per sector Computer Mainboard : P4M800CE-8237 BIOS : Phoenix Technologies, LTD 6.00 PG 12/22/2005 Bus(es) : ISA X-Bus AGP PCI IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DDR Chipset Model : VIA Standard Host Bridge Front Side Bus Speed : 4x 133MHz (532MHz) Total Memory : 2GB DDR Memory Bus Speed : 2x 200MHz (400MHz) Memory Module(s) Memory Module : Patriot Memory 1GB DDR PC3200U DDR-200 (3-4-4-8 2-12-0-0) Memory Module : PNY 1GB DDR PC3200U DDR-200 (3-3-3-8 2-11-0-0) Video System Video Adapter : Radeon X1950 Pro (PS3.0, VS3.0 573MHz, 256MB 688MHz, AGP 3.00) Storage Devices ST3160812A (160GB, ATA100, 3.5", 8MB Cache) : 149GB (E:) WDC WD2000JB-00GVA0 (200GB, ATA100, 3.5", 7200rpm, 8MB Cache) : 186GB (D:) AOPEN DUW1608/12X (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices BIG HAL (C:) : 233GB (NTFS) New Storage (E:) : 149GB (NTFS) @ ST3160812A (160GB, ATA100, 3.5", 8MB Cache) New Audio (D:) : 186GB (NTFS) @ WDC WD2000JB-00GVA0 (200GB, ATA100, 3.5", 7200rpm, 8MB Cache) Optical Drive (F:) : N/A @ AOPEN DUW1608/12X (ATA66, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : VIA VT8237 PCI to ISA Bridge LPC Legacy Controller 1 : ITE IT8705F Audio Device : Biostar Microtech VT8233/A AC'97 Enhanced Audio Controller Audio Codec : Gammagraphx 0000h Audio Codec : Gammagraphx 0000h Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Biostar Microtech VIA SATA RAID Controller Disk Controller : Biostar Microtech VT82xxxx EIDE Controller (All VIA Chipsets) USB Controller 1 : Biostar Microtech VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 2 : Biostar Microtech VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 3 : Biostar Microtech VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 4 : Biostar Microtech VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 5 : Biostar Microtech VT6202/12 USB 2.0 Enhanced Host Controller SMBus/i2c Controller 1 : VIA VT823x SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP DeskJet 930C/932C/935C (1200x1200, Parallel, Colour) Printer : HP DeskJet 930C/932C/935C (300x300, Colour) Printer : Acrobat PDFWriter (600x600, Parallel) Printer : AdobePS Acrobat Distiller (4000x4000, Colour) Network Services Network Adapter : VIA Rhine II Fast Ethernet Adapter (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Re: Unable to install PT -- "procedure entry point" error
Could this be the problem?
Known Incompatibilities Caution - Mbox is NOT supported on the following systems or systems with the following components:
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox 09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox 10/31/2009 - Win 7 64Bit MBox /PT not supported under Win7 - I didn't leave PT, PT left me! 11/30/2009 - MBox, REAPER http://www.jazzmandan.com |
That, plus the VIA chipset with an Intel processor has been a no-go for most everyone that has tried it.
Okay, I could install the drive into my other computer. Please take a look at the Sandra Report for that one and let me know if you forsee any problems with the Pro Tools install.
-------------- SiSoftware Sandra Computer Model : MICRO-STAR INTERNATIONAL CO.,LTD MS-7529 Workgroup : UNIVAC9000 Host Name : UnivacMain User : Bruce admin Processor Model : Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed : 2.34GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : MICRO-STAR INTERNATIONAL CO.,LTD G31M3-L V2(MS-7529) BIOS : AMI V2.4 03/26/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 Chipset Model : MSI P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 334MHz (1.34GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Mushkin 991558 996558 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : Mushkin 991558 996558 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Video System Video Adapter : NVIDIA GeForce 9500 GT (32 SM4.0 1.4GHz, 1GB DDR2 2x400MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 9500 GT (32 SM4.0 1.4GHz, 1GB DDR2 2x400MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 9500 GT (32SP 4C 1.4GHz, 1GB 2x400MHz) Adapter : NVIDIA GeForce 9500 GT (1005.6MB 2x400MHz) Storage Devices Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 466GB (C:) HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 466GB (NTFS) @ Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : MSI 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : Fintek F71882FG/F71883FG Audio Device : MSI 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semiconductor 888 High Definition Audio Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : MSI 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : MSI 82801GB/GR/GH (ICH7) Serial ATA Storage Controller USB Controller 1 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 2 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 3 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 4 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 5 : MSI 82801G (ICH7) USB 2.0 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP DeskJet 930C/932C/935C (1200x1200, Parallel, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek RTL8101E Family PCI-E Fast Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
You will have no joy with a single internal HD, PT LE requires separate physical drives for system and recordings.
<<Logical Storage Devices Hard Disk (C:) : 466GB (NTFS) @ Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache)>> But a second internal SATA HD is a cheap investment. But hold it... what this...?? Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 I predict problems until Win7 64 bit is supported with new drivers! See my signature. One more thing, "There are known issues with NVidia graphics cards." There is another thread running right now on this topic. Isn't PT LE wonderful!!
Yeah, I was going to take the already prepared hard drive from the XP computer and put in in the Vista.
But the rest of your message.... omfg. |
PT7 Procedure Entry Point Error?? | Eddie D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-07-2005 03:00 PM |
Procedure Entry Point Error - Any Ideas? | bousley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-18-2005 07:00 PM |
Procedure Entry Point Error | Producers Never Sleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-23-2004 08:36 AM |
Procedure entry point - error | Jeff B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 02-01-2004 09:57 AM |
"Entry Point Not Found" error | Armando Romeu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-30-2003 02:53 PM |
