5.1 file channel order
does anyone know how PT manages interleaved multichannel files when importing them? Is there any signature in the file which tells about the track order and does PT read it? I have 5.1 files from several sources and the tracks are mixed up all the time. C is R or LFE/LS/RS vs. LS/RS/LFS. All this film/smpte/dts stuff. it's a pitty that you are never sure. Ambiences are hard to analyse whether R and C is in the right place. |
Re: 5.1 channel order
Hi: that info should be part of the file header, or the metadata.
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
I do a lot of 5.1 for network TV and film. I always deliver in six discrete mono files and ask the same to be supplied to me. That way no mistakes are made.
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
For AAF export I always split the 5.1 tracks into the proper SMPTE order from top to bottom prior to export. |
Do you know from which PT version it works this way? Used to be a complete mess from version to version. Film layout export but SMPTE import and vice versa depending on the version and never really documented or flagged in the fixed bug reports. I just tried this by exporting a 5.0 file via commend-shift-K twice. Once in film and once in SMPTE order set in default path order and both came out at SMPTE order. What's your secret? Many thanks! Frank
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Take this FAQ above. I know for a fact I was outputting SMPTE order files in July of 2016 when that FAQ was written. Despite it saying PT can't do that. At some point, I think with PT11 they switched the output to default to SMPTE order. I would ask for an option box to check on export but honestly the only times I deliver interleaved files are for clients that require SMPTE so it hasn't been a big deal. Otherwise I use multi-mono.
~Will |
Pretty sure PT always exports files in SMPTE format, and always shows them in FILM format. I don't think you have any control at all over either.
Just ran 3 tests. Always exports SMPTE order. Always shows FILM order. Doesn't matter what path order is set in I/O. FAQ is wrong (even used Cubase to import/export 5.1 files from Pro Tools and always the same; in that way it's good news as everything stays outputting/routing correctly)
Obviously it depends on the source if it is creating it, but yes, there's a metadata block of "wave extensible format" in the wave file that Pro Tools (and other audio/video programs) is reading. Cubase has an option to turn off writing that chunk and then things go wrong. Otherwise both Pro Tools and Cubase are writing a SMPTE order chunk and importing into the respective DAWs with correct track order -- Cubase is SMPTE inside the DAW and Pro Tools is FILM inside the DAW.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 12-15-2018 at 11:36 PM. Reason: bolded important part. if the source isn't creating it, then there's no guidance for Pro Tools |
5.1 file channel order | lastbeethoven | Post - Surround - Video | 49 | 06-22-2019 03:44 PM |
CAF channel-order still wrong in 9.0.5 | Arno Peeters | Post - Surround - Video | 3 | 07-26-2015 07:55 AM |
Locked Channel order in Bus | bcslaam | Pro Tools 11 | 3 | 08-29-2013 12:11 PM |
