AAE 6101 Errors
Will we still be getting those AAE 6101 errors, in/with 2018?
Two audio tracks, three inserts each, two Aux tracks, one Master fader, and PT 12.8.3 is telling me I have too many things going on.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Re: AAE 6101 Errors
Was having these issues on 2018.1. The answer for me was unchecking “ignore errors” in playback settings.
Re: AAE 6101 Errors
Along with what Kevin said, in the same dialog box, uncheck dynamic plug-in processing and set your disk cache to a number (like 3g).
And you likely already know this, but if you start Pro Tools while holding down the N key you can set it up this way once and all subsequent new sessions will have these same settings until you change them. Do those things first. Trash prefs. See if you still get the 6101 error.
Brian See profile page for system details |
Re: AAE 6101 Errors
Thanx, for the suggestions. I'll try them with V 12, before moving up to 2018.
Re: AAE 6101 Errors
*UPDATE*
I tried it, and noticed, that "Ignore errors" was already checked. Disk cache size was set to "normal"; I set it to 3g. We'll see how it goes.
Re: AAE 6101 Errors
i hope one realises that when unchecking dynamic processing a plugin doesn't release it's resources on playback stop or playing over silence.. this means the cpu is always working way harder on a busy project.
i don't recommend it.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
Re: AAE 6101 Errors
Sent from my Pixel 2 XL using Tapatalk |
Re: AAE 6101 Errors
Counterintuitive, but I'll try it, anyway.
Thanx!
Re: AAE 6101 Errors
yes but as the first answer described, pro tools works better with it unchecked.
Theoretically, i thought that option would mean one would never get an overload message and would just put clicks and pops in the audio if it couldn't handle the load, like S1 does for example, or Cubase. But it seems even the naming of the option itself is counter intuitive! Anyway FWIW, i have dynamic ON here and Ignore OFF. Hope things improve for you. PS what buffer size you working with?
Re: AAE 6101 Errors
The buffer size is a valid point. (Y)
I have it at 32 samples. I'll try 64 and see. Thanx, for that!
-6101 Errors | TrentWilliams | Pro Tools 12 | 7 | 03-20-2017 11:51 AM |
AAE 6101 errors. Pro Tools 11 HD. Help! | Ke productions | Pro Tools 11 | 4 | 04-25-2014 11:39 PM |
PT 10 6101 and 9128 errors | spaceman | macOS | 13 | 03-12-2012 02:03 PM |
6101 AND 9128 ERRORS | LUISMI | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-09-2008 06:24 AM |
-6101 errors all the time | blastula | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 03-03-2007 07:16 PM |
