Old 04-15-2021, 07:14 AM
blue-element blue-element is offline
Default Monitor setting in PT 2021
I'm working with 2 Monitors, on left side is the Mixing window and on the right side there is the Event window. I have tried to set this for every session, but when I open a session once more I have only the Event window on the right side. So I must klick on the Mix window and must grab it to the left side. Is there a special Setting in PT to have the windows on the correct side on the monitors when i open a session ?
Old 04-15-2021, 08:05 AM
Default Re: Monitorsetting in PT 2021
Not much info to go on If you are running Windows, set everything how you want and then hit Alt-F4 to close Pro Tools. That should make it open the same way next time(at least it used to work this way). If that doesn't help, then come back with a lot more details like"
OS?
Monitor resolution(for both screens)?
Scaling setting(if its been changed)?
Old 04-15-2021, 09:42 AM
OK, my System is Mac 10.15.7 on PT 2021.3.1
Is there an identical Setting to close PT as you have mentioned with Windows ?
Old 04-15-2021, 11:50 AM
Ben Jenssen's Avatar
Default Re: Monitor setting in PT 2021
Same here.
This hasn't worked well in a long time for me, PT opening sessions and forgetting window settings.
I've given up.
Everytime I open a session on my dual monitor setup, mix window is like it should be, full-screen on monitor 1, I have to activate edit window and drag it to monitor 2 and make it full screen. Everytime.
Also, allthough it might be a different issue, PT is rubbish with remembering hidden status of tracks and open/collapsed track folders.
Edit: Sorry, I was talking about apple's "spaces" and not displays. Although PT have never been good with either.
Old 04-15-2021, 12:25 PM
BScout BScout is offline
Not a proper solution but a workaround that might be more convenient, can you not save a Pro Tools Window Configuration for what you want? Then you can recall if it isn't right.
Old 04-17-2021, 12:31 AM
Originally Posted by Ben Jenssen View Post
Same here.
I've given up.
As I can hear you have the same problem, for me the chapter is finished. No problem I can live with it
Old 04-17-2021, 01:37 AM
JFreak's Avatar
JFreak JFreak is online now
This.
The problem is OS wide. If you have two monitors and windows on both monitors, as soon as your monitors go off (power saver during the night) once they are powered on all windows are on main monitor.
Janne
Setting up a headphone mix-anyway to monitor? Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-19-2009 11:02 PM
Setting up a second monitor? jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-07-2005 04:51 PM
OT: Monitor Setting Weirdness donkerce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-01-2005 06:11 AM
Monitor color setting pbjnus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-18-2005 08:56 AM
