Old 11-19-2010, 12:43 PM
xeshaka xeshaka is offline
Default Original Mbox on Windows 7
I honestly searched and cannot find a clear answer on this. Maybe I'm just bad at searching.
I have the original Mbox that came with Protools 6.7. I purchased the upgrade to 7.4 a while ago. I used to use it on an older Macbook I had, but it's falling apart fast. My question is, how can I install Protools on my new Windows 7 system? When I try to run the install from the disc it says it is blocked due to compatibility issues. How can I upgrade Protools if I can't install it in the first place? Is there a way to download a newer version Protools LE from Avid's site? I can't seem to find any link.
Any help would be greatly appreciated.
Thanks
Old 11-19-2010, 12:52 PM
spkguitar's Avatar
Default Re: Original Mbox on Windows 7
To work with Windows 7, you would need to purchase the upgrade to Pro Tools 8, and then upgrade to 8.0.4
Unfortunately, support for the original mbox ended with 8.0.1, so even more unfortunately, you are out of luck.
Sorry.
Old 11-19-2010, 12:58 PM
Ok, thanks for the quick response. I might try to install XP on my PC as a dual boot option. Or maybe I'll try to find a new mbox on ebay :/
Old 11-19-2010, 01:05 PM
Does the same apply for Windows Vista? I have a copy of Vista Home Premium.
Old 11-19-2010, 02:00 PM
sunburst79 sunburst79 is offline
As long as its 32bit it its worth a shot. As previously mentioned your still going to be stick at 8.0.1
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-19-2010, 02:05 PM
Come to think of it I just installed Vista Buisness 32 bit on a 6 core AMD machine about a month ago and lent it along with my MBox to a friend to write demos with. It seemed to run fine here and I haven't heard any compliants from her so I'm assuming it's all good.
Scott
Core 2 Specs Page
Old 11-19-2010, 08:29 PM
Awesome, I'll give Vista a shot :)
Old 11-19-2010, 09:21 PM
As always your mileage may vary. Keep in mind I did not test this extensively but it seemed stable and had no PT related problems except as noted below. This was with the latest MBox compatible version of PT 8.0x. Which I beleive is 8.0.1cs3.
You should be fine with Vista. Just make sure to optimize the machine per Avids recommendations.
EDIT: knowing what hardware your installing it on would be helpful. Let us know how it works.
Scott
Core 2 Specs Page
Original Mbox 1 on Windows 7 kverse Digidesign Hardware & Software 8 01-06-2024 04:28 PM
Windows 7, Pro Tools LE 8.0 and Original MBox. Is it possible? RuffinMedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 07-11-2017 08:47 AM
Original Mbox not installing on windows amac84 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-17-2010 10:08 AM
Original MBox with Windows Vista or Windows 7 JoshuaD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-16-2009 06:57 AM
Original MBox on Windows Vista or Windows 7 JoshuaD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-16-2009 06:50 AM
