Old 01-18-2003, 07:38 AM
xian$ xian$ is offline
Default HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well
Can anyone answer my questions, because it seems sales people and support people can't. I am upgrading from a P3 650mhz PC to a P4 2.0 ghz Dell laptop that is loaded. I have finally decided top buy the DIGI 001 as well, but I have only now come to learn that the DIGI 001 cannot run on a laptop due to the PCI slot I would need to run the DIGI 001. I really don't want to get another Desktop, but I definitely need the 001, not the Mbox... the 002 would solve this problem but I can't swing that kind of money...how would the 001 run on my desktop, which again is a P3 650 mhz with 256 RAM? Help so I can go buy something soon...thanks!
Mac Mini 1.5GHz Intel Core Solo, 512 RAM, Mbox, PT 7.1, Oxygen 8.
Dell Inspiron 9300 1.0 RAM, Mbox PT 7.0, external firewire drive, Oxygen 8.
Old 01-18-2003, 07:52 AM
J. FO J. FO is offline
Default Re: HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well
check the compatibility docs to see if your MOBO will work with PT. a 650 will do a decent job, but your plug-in count will be low. my advice, go for a little less of a laptop and use the extra money to upgrade your desktop's MOBO, cpu, and add a stick of memory. OR, start donating plasma every chance you get until you can get the 002.
Jeremy Forbis
Old 01-18-2003, 09:23 AM
Captain_Pants Captain_Pants is offline
Shopping with intent is usually illegal to most females of Wife or Girlfriend status, how do you fair?
Ill suffer winter alone;
ten thousand miles from home...
Old 01-18-2003, 09:32 AM
mix2much mix2much is offline
In order to get the digi 001 to work with a laptop, you need to get a pci expansion chassis. I'll tell you now they aren't cheap. Mine was $800 I believe. If you combine that with the price of the 001, you've practically paid for the 002 which will give you better conversion, more and better mic pre's and a control surface! Plus having to lug around the extra box is a drag...trust me. I wish the 002 was available when I bought my laptop. The only upside is you can use an ata-ide drive with the expansion chasis. So external drives would be quite inexpensive. If you still want to go this route, visit www.magma.com
Old 01-18-2003, 10:49 AM
8mmOverdose 8mmOverdose is offline
Originally posted by mix2much:
In order to get the digi 001 to work with a laptop, you need to get a pci expansion chassis. I'll tell you now they aren't cheap. www.magma.com
<font size="2" face="Verdana, Arial">i agree, for that price you could buy the 002.
Old 01-18-2003, 11:53 AM
...Thanks, I understand a lot now as far as the laptop goes...I have to make my mind up, as for my old PC...how would that run the digi 001? PIII 650 with 256 mb RAM
~thanks!!!
Building a workstation or buying a Dell dwfender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-15-2010 09:54 AM
Need help in Buying a laptop bassbuddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-01-2008 12:06 PM
buying a laptop /HELP!!/I did read the laptop post psus15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-02-2004 01:32 PM
Buying Dell 2300 for mbox? roseberrye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-27-2002 07:07 AM
Buying new Dell Computer for Digi001 jab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-23-2002 07:33 PM
