  #31
Old 10-29-2018, 09:47 AM
Tweakhead Tweakhead is offline
Default Re: (NEW) Eventide SP2016 Reverb Plugin
Originally Posted by chrisdee View Post
snip . . . There is a 97 samples delay when I work at 96k. Is there any way to turn off the delay so it's latency free?
Command plus Control plus Click on the Delay Compensation number in the Mix Window. Does that do it?
  #32
Old 10-29-2018, 11:00 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Thanks. But that only disables delay compensation for that track. It doesn't remove the delay in the plugin.
  #33
Old 10-29-2018, 11:24 AM
pmcculloch pmcculloch is offline
@chrisdee: are you asking whether you can have a predelay of 0 ms?
The promotional prices are good through the end of the month, I believe.
  #34
Old 10-29-2018, 10:33 PM
chrisdee's Avatar
The plugin adds a latency when i insert it on a channel. Im asking if its possible to disable this so i get zero latency?
  #35
Old 10-29-2018, 11:10 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Don't all plugins add latency? Some more than others, but it's the cost of processing the signal.
Justice C. Bigler
www.justicebigler.com
Head Audio/A1 Blue Man Group: Speechless tour
Home/mobile: Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Focusrite Red 8Pre / Protools HD Native 2018.10 Ultimate
  #36
Old 10-30-2018, 02:38 AM
chrisdee's Avatar
No. Most of my plugins have zero latency. Many plugins does have a latency. Some more than others. I try to avoid plugins with latency since I work with arangement and recording. Multiple plugins with latency adds up and affects performance and timing when recording.
  #37
Old 10-30-2018, 08:52 AM
JFreak's Avatar
JFreak JFreak is online now
In a DSP world, yes. But if we're talking about native plugin processing, it all happens within native playback buffer (or if it doesn't happen, spikes an error).
Some plugins however, whether DSP or native, are designed to produce latency by their nature. Take a look-ahead limiter for example; you cannot see the next sample before it happens, so you need to delay the signal to at least one sample (in case processing is zero-latency otherwise) to be able to process with that look-ahead design. This latency is something any buffer cannot ever compensate.
Janne
  #38
Old 10-30-2018, 10:53 AM
I can understand your desire to avoid latency, but zero latency is not possible here because the plugin resamples the wet path to operate the algorithm at the original SP2016 sample rate (~39 kHz). This is a key aspect of the sound, but it requires some latency. The older plugins are able to have less latency because they don't do this, but it's also why they don't sound as close to the original.
If you're concerned primarily about latency on the dry signal, running the effect on a send will, of course, help, though it's not quite the same as having no latency.
  #39
Old 10-30-2018, 11:54 AM
amagras amagras is offline
Inserting on a send will still add latency when recording but if you don't mind having extra pre delay you can turn off ADC for the send channel.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
  #40
Old 10-31-2018, 12:41 PM
Just as a heads up, the promotional prices for SP2016 Reverb have officially been extended to 11:59 PM EST, November 5, 2018.
HTML code is On
Eventide Reverb AAX JFreak AAX Plug-ins 25 08-28-2014 11:45 PM
Eventide Reverb opinions soul Pro Tools TDM Systems (Mac) 4 03-16-2010 10:40 AM
Eventide Reverb lifer Pro Tools TDM Systems (Win) 2 03-15-2010 02:37 AM
OT. Eventide Reverb GS-DK Pro Tools TDM Systems (Mac) 11 03-07-2010 12:21 AM
eventide reverb is here Belushiman Pro Tools TDM Systems (Mac) 3 02-12-2004 07:05 PM
