Audio Engine probleme
Hi all Protools Users,
I am running Protools 2018-4 on my iMac core i5 3.3 MHz with 24 Mo RAM My OS is Mac OSX High Sierra My "sound card" is a Behringer X32 Rack I also own an S3 station Until now everything was OK but yesterday when i tried to load the last projet i made, i have a strange message stating that "Protools was unable to find the sample rate frequency on the mentionned value" (or something like that. I am french and tried to translate. Reinstall Protools but always the same message My Behringer X32 work fine with Ableton Live and all my gear hook to it Any help Thans a lot MaxIdingue enclosed the french message |
Re: Audio Engine probleme
It might be a sample mismatch between Pro Tools and the X32. What is the sample rate of the session and what sample rate is the X32 set to?
I had a similar issue using Protools with the x32. It was because the board was in sync with another X32 (it was switched off) that was giving word clock to the one I was hooked. So check the set-up menu of the X32, see if switching it to internal sync will work.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
Thanks a lot Emi. My X32 synchro is OK set to internal and sample rate to 48 kHz.
Anyway, i read somewhere that the audio engine has changed between Protools 11 and 12 from DAE (Digital Audio Engine) to AAE (???) or something like that. So i reinstall PT 11 than upgrade to PT 12.8 and............ It work now I wonder if i can upgrade to PT 2018 now ??? SIncerely Maxidingue |
Why not ? You can have both version: 12.8 and 2018.4. Just rename the old one 12.8 to v12.8 for example BEFORE installing the last version. And so, you could switch between both.
I'm always doing that when a new version appears.
WIP house Prod - home studio iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61 STUDIO PRO Post-prod MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic. |
The DAE was only 32 bit and was used from 10.3.10 and below. The AAE is the current version and was introduced from 11.0.0 and is a complete rebuild from the gound up (Avids words) and is the architecture is now 64bit which is the same as in 12 and 2018.
Thanks Christopher,
Anyway, i re install PT 11 than 12.8 and now 2018-4 and it work fine Regards Maxidingue |
Audio engine | digiplex | Pro Tools 2018 | 7 | 04-09-2018 02:08 PM |
64 bit Audio Engine? | Numi | Pro Tools 11 | 1 | 04-28-2013 01:29 PM |
No m-audio interface in current engine (playback engine) | SlicerSounds | Windows | 1 | 10-04-2012 12:27 AM |
PT probleme | Shevanelflip | Pro Tools 10 | 3 | 03-07-2012 07:59 AM |
Audio Engine | twistedblues | Tips & Tricks | 1 | 03-24-2004 06:25 AM |
