Why can\'t I monitor RTAS on Insert A? Line6 Gearbox RTAS
Just purchased Line6 Gearbox plugin and when I insert it on an audio track and hit I or R, it bypasse's the plugin automatically and I can't hear it. Why is this Digi? I know the trick about putting a TDM plugin before an RTAS plugin and then it works but that seems bogus to me. Shouldn't we be able to monitor live input in RTAS plugs in real time? Can I get a technical reason why this is?
Using Pro Tools 7.3 on Mac G5 dual with Pro Tools HD|2 (Non Accel)
Justin (Proud Pro Tools Ultimate PERPETUAL license owner) Admin www.elevenrackpresets.com Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD |
Re: Why can\'t I monitor RTAS on Insert A? Line6 Gearbox RTAS
RTAS plugs are disabled when a track is set to record
you could put the plug on a parallel AUX track for monitoring and mute the record track during the recording
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
With Pro Tools 7, we made it so that you could use RTAS plug-ins on any track type, where previously you could only use them on audio tracks and then they must go before any TDM plug-in on the track. With the removal of most of those limitations, there came the block to being able to use RTAS plug-ins during record on an audio track if you wanted to monitor on input, which is what you're experiencing. Putting the TDM plug-in in the slot above is the workaround. We felt this limitation was far less obtrusive than all the other ones were in the previous system.
The only problem is that even at the lowest latency setting...it's still too much to play guitar or bass
But if you are using Logic or Cubase with a fast device...like the Fireface, then you can make it playable with latency settings as low as 32 samples.
www.olipoulsen.com iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7 Apollo 8 / PT Ultimate 2020.9.1 |
Can I do this with Line6 Gearbox | TheBaron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-29-2008 07:47 AM |
Line6 GearBox Plug-In Gold Bundle With PT LE | TongWunFung | Digidesign Hardware & Software | 1 | 05-06-2008 11:06 AM |
Anybody using Line6 Gearbox Plugin | The Dougfather | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-05-2008 02:04 PM |
Line6 Echo Farm RTAS? | DigiDubsman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-02-2004 08:37 PM |
Why the hell is Line6 not releasing an RTAS amp plugin??? | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-25-2003 08:19 AM |
