PT9 incompatibility with Madixtreme 128 in OSX
We just recently setup a neat Madi system in our studio, using Madixtreme 128 cards to get audio to/from our one live room to our 6 project studios over fiber lines. Unfortunately, PT9 is not compatible with the Madixtreme 128. Something about it's i/o limitation. I've tried to contact Avid support but my complimentary support code ran out 2 weeks ago and I don't feel like spending the money on a new code to contact them about a problem with there software. Anyone had experience with this and/or know whats going on with it? SSL says they are working on a fix, but I'm not holding my breath. I would really hate to have to switch all of our workstations over to Logic or DP, but at the moment I don't really have a choice...
Re: PT9 incompatibility with Madixtreme 128 in OSX
We are having the same problems with our main control room equipped with a SSL MadiXtreme 128. Pro Tools crash on startup when trying to create DAE objects.
In our secondary control room where running on a MadiXtreme 64 which is working fine with Pro Tools. I've been in contact with the SSL support which confirmed the problem to be caused by the large amount of inputs and outputs on the card. They are looking for a fix but since the card is using Core Audio and working fine with both Logic and Ableton Live (I've confirmed this on our machine) they claim they can't do much at the moment. The problem seems to be in Pro Tools so it probably has to be fixed by Avid. To bad since we're running 40+ machines with Pro Tools 9, all working fine, except for this one. Would be sad to have to do all major sessions in some other DAW. |
The 32 IO limitation I can't do anything about, but crashes are another matter. If you can provide all the details about your problem and system from the Help Us Help You sticky I'll see what I can do. The same would go for [email protected] |
So is there a 32 track limit with MADI as far as how many tracks can go into record at once? I have the RME MADI interface and can't seem to get more than 32 tracks recording at once. If this is true, what is the workaround? TIA
System Details: Macbook Pro 17" OS 10.7.5 PT 10.0 8 gig ram FW Drives (Multiple) eSATA Drives (Multiple) [email protected] |
I do indeed experience crashes every time I launch Pro Tools. The splash screen is displayed and everything seems to be okay until "Creating DAE Objects" is shown, where it halts and crashes after a second or two.
Zapping the PRAM or resetting SMC don't fix the issue. Even in a clean install of OS X 10.6.7 with just OS X (first with and then without patches through Software Update), MadiXtreme drivers and Pro Tools 9.0.3 the problem still occurs. I have an almost identical setup running Pro Tools 9.0.3 HD with a MadiXtreme 64 which is working fine so the problem seems to be with the MadiXtreme 128 card. Both Apple Logic Pro and Ableton Live as well as system audio is working fine with the setup so problem seem to be with Pro Tools. My system specifications are: Mac Pro (4,1) with Quad-Core Intel Xeon 2.26 GHz. 12 GB RAM (DDR3 ECC 1066MHz) Nvidia GT 120 display card on PCIe slot 1 SSL MadiXtreme 128 on PCIe slot 2 (connected to two SSL AlphaLink through MADI cables) Two HDD (both SATA, formatted with one journaled MAC OS Extended partition) - Hitachi HDE721064SLA360 640GB for OS X - SAMSUNG HD501LJ 500GB for audio Both network port are used - en0 for Internet access - en1 for connection to our Avid ISIS 5000 USB only connects mouse and keyboard (through USB extender) Software: Mac OS X 10.6.7 (also tested with 10.6.3 and 10.6.6 and with and without latest software updates) Pro Tools 9.0.3 HD (also tested with 9.0.2) SSL MadiXtreme drivers Here also is the conversation with SSL support: Quote:
There is no workaround - it's simply a limitation of Pro Tools 9. Only Native HD and HD TDM offer more IO with Pro Tools.
I too have been in contact with SSL, and they told me something quite different. They said they were working on a work around, probably something to do with disabling some of the inputs. I understand that PT9 native has limited I/O, but it would be nice if we could still use the program and be able to disable inputs and outputs instead of it just crashing. I actually don't need all 128 i/o, but I do need access to both madi ports. There has to be some kind of way to make this work...
"Playback of up to or a combination of playing back and recording up to 192 mono tracks or 96 stereo tracks (192 available voices) at 44.1 kHz and 48 kHz"
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Perhaps, if we wanted to spend $2,000 per computer... although that is referencing tracks within a session. We are talking available inputs from a hardware device. Not sure if that actually means more i/o...
SSL Alpha Link MADI AX & MADIXtreme Bundle $1999 | Jantzen | Buy & Sell | 2 | 07-18-2013 11:09 AM |
does protool 11 works with ssl alphalink ax and madixtreme? | mjhstudio | Pro Tools 11 | 1 | 06-18-2013 09:16 AM |
Pro Tools 10 and SSL MadiXtreme | Dot | Pro Tools 10 | 1 | 04-14-2013 03:32 PM |
CPTK 2 license & SSL Alphalink MadiXtreme 64 Bundle | hotsizzlemusic | Buy & Sell | 2 | 10-08-2012 12:05 AM |
"Pro Tools could not set sample rate to specified value" error with MadiXtreme | redbull | Windows | 2 | 08-26-2012 09:45 AM |
