Old 07-18-2019, 09:58 AM
Zergei72 Zergei72 is offline
Default PT 9 on a Fujitsu Siemens AMILO LA1703
So ...
I'm trying to run PT 9 on a Fujitsu AMILO LA1703 - laptop pc .
I know it has only 2GB of RAM, but a trial and error case here .
Pro Tools launches and then the system powers / shuts down .
I know it must be the lack of RAM or it may be due to overheating (the laptop is running quite hot) .
The laptop has Windows 8 x64 on it .
Now if I'd go for example Windows 7 SP1 x64 and invested in another 2GBs of RAM (there's a possibility it can take 4GBs, based on conversations I've read online) and maybe go for a AMD Turion instead of sticking to the Sempron it has now or so ... Would that help matters ?
I know the machine is a rethrosaur, but what the hell ... so am I (((:::
- Zergei -
Old 07-25-2019, 11:04 PM
peterle peterle is offline
Default Re: PT 9 on a Fujitsu Siemens AMILO LA1703
forget it , even 4 gb ram is much underpowered , the low end cpu too ,
and the amd cpu may cause errors too , intel is much more compatible,
i7 cpu recommended by avid.
if your laptop is running hot and shuts down when pt starts ,
it may be full of dust and cpu + gpu may need new thermal paste...
makes no sense on such computer to spend money or time.
btw a 64 bit os with 2 or 4 gb ram makes no sense,
the reason to go 64 bit is mainly to adress more ram than 4 gb ,
the 64 bit windows version needs alo more ram for himself than in 32 bit.
foley artist , soundeditor
[IMG] code is Off
Fujitsu AMILO M3438 and pro-tools? TonserPerson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-30-2005 06:58 AM
FUJITSU LIFEBOOK E7010?? erna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-10-2003 02:14 AM
Fujitsu Siemens Amilo D8820 2.53Mhz Digi 002 SEBJOERG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-31-2003 12:05 AM
wave driver on a fujitsu umashankar Tips & Tricks 0 02-24-2003 07:18 AM
Fujitsu Drives Wayne Swingle Pro Tools TDM Systems (Mac) 1 08-01-2000 05:35 AM
