Old 04-02-2021, 01:04 PM
Roger Stauss Roger Stauss is offline
Default S6 M40 Shell error
Our S6 runs for 30 minutes then freezes with the a Shell Error. I'm on my second replacement MM for the same problem. Support suggests reloading the software 2020.11.1.10
Anyone else having this problem?
Thanks,
Roger
Old 04-02-2021, 02:32 PM
creativecontrol's Avatar
Default Re: S6 M40 Shell error
Greetings,
It's very likely that this is related to the disk system - specifically a failure of the Master Module SSD. Have you started a case yet?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-02-2021, 05:37 PM
Thanks Jeff. I have a case started. It's bewildering. I'm on my second replacement for the same issue in just a few weeks. Another unit is being shipped early next week.
Old 05-27-2021, 09:58 AM
Bastieng Bastieng is offline
Hello,
I ran into a similar problem, going into shell and now booting straight to shell every time.
I'm about to start a case but did the SSD change solve the problem?
Old 05-27-2021, 11:14 AM
Hi there. Yes. Avid sent a replacement master module. I went through 3 modules before I got one that was stable. All is well now.
Old 05-27-2021, 11:57 AM
Ok thank you, I'll go through the same route then.
Shell Error laki Avid S4/S6 2 03-20-2018 03:25 AM
Clam Shell? paldry macOS 3 10-04-2011 07:00 AM
Before I shell out 300$, I have a question Violins77 Pro Tools SE and Essential (Win) 4 03-24-2011 02:41 AM
VST Shell update The Lone Roger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-23-2006 10:15 AM
Can i run ProTools w/ Digi 002 in OS9 shell? DAE ERROR! polish_your_music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-30-2003 05:01 PM
