Macro triggering track layouts and PT memory locations switch.
Hi all,
So I've been using soft keys to trigger Track Layouts on the S6 and at the same time change change PT Memory locations which have programmed visible tracks. So I flip my custom layouts to dialogue, music, verbs etc etc etc. It's really handy because it's less clicking but I ran into the following issue - I'm currently on an M10 which can only assign 24 tracks to a layout which sometimes is too little for a given food group. Instead, I figured I'll just go out of Layout mode for that and just let the S6 display all the tracks visible in PT so I can bank. So in short I need a way to tell the S6 to go OUT of track layout mode. I can't find a command like that so for now my work around is to trigger a layout and then trigger it again (with a delay of 50ms) and that switches it out. It's not consistent though - probably 50% of the time it works and the rest of the time it doesn't switch out from the layout mode. Any idea how I could achieve this easier? Also, unrelated - sometimes when i hit preview all my tracks light up green as if I touched everything. I have to go out and back into preview to un-green everything. Any idea what's happening? Thanks!
Peter Re-recording Mixer |
Re: Macro triggering track layouts and PT memory locations switch.
Greetings,
It sounds like a timing issue. I believe you are approaching it in the correct way. The surface function mapped to trigger recalling a 1:1 layout is also used to close the same layout and return to standard banked channels view. I know they are working on refining a lot of the soft key triggers in the current effort. Perhaps Eddie can comment on it. best, Jeff |
Is there a different way to close layouts? I've been trying to get this specific function to work in different ways and can't seem to get a consistent output.
No. There are Surface functions for closing Spill Zones - L & R, for recalling Layouts - and on 2nd press the Track Layout is closed.
Jeff |
I ended up removing the double press and instead now press Shift + Layout buttons. Maybe in some update you can add the ability to create shortcuts to any of the keys on the surface :)
Quick ways to rename Memory Locations in Memory Locations Window? | tomfarleymusic | Pro Tools 2020 | 3 | 05-09-2020 07:12 AM |
Memory Locations - Track Show/Hide not working | hocusprocus | Pro Tools 12 | 9 | 08-09-2016 12:30 AM |
Set up memory locations to show different track view selectors | phillyt2k | Pro Tools 10 | 3 | 04-15-2013 11:06 PM |
Memory Locations - Track Show/Hide | stargazer | Pro Tools TDM Systems (Mac) | 2 | 10-14-2010 12:03 AM |
Triggering Click Track with a Foot Switch | donnercruz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-24-2010 02:44 PM |
